Got valves out....how do you tell what wrong???
Old Jun 20, 2004 | 03:20 AM
CrippleFightin's Avatar
My pistons have marks on them like they hit the valves, but I am looking at the valves and it doesnt look like any are bent.....So how can you tell if the valves are messed up once they are out?
Someone has gotta know....I damn sure hope I didnt take this **** apart for no reason. What should I use to smooth out the pistons with? Will sand paper work? Are the pistons aluminum?
Old Jun 20, 2004 | 05:05 AM
MasterEvilAce's Avatar
there's some blue crap you put around the edge of the valves.. then you slide the valves into the head, and apply some pressure, and spin them a quarter turn.. then pop them out without touching the area you applied the crap to..
You could see a clean line going all the way around the edge.. if that's the case, then the valve is seating properly and making a good seal... and put the valve on a flat surface, like a table.. make sure it doesn't WOBBLE or anything, so you know the head is flat... and as long as the valve stem doesn't look bent or anything, it should be fine..
that's practically all i can remember about the valves from my auto tech class... hope this atleast helps a bit
Old Jun 20, 2004 | 10:39 AM
Anyone else?
Thanks for the info.
Old Jun 21, 2004 | 12:23 AM
mullettour's Avatar
I think the pistons have valve reliefs in them so if all the pistons look the same that's probably what you're seeing.
Old Jun 21, 2004 | 01:04 AM
AL SS590 M6's Avatar
Moderator
No valve reliefs in stock LS1 pistons. I'd take the valves to a machine shop and heve them checked. Chances are that they ARE bent. If you don't know of a local machine shop ask at your auto parts store they'll know where to send you. And check your pistons very carefully for cracks. Hypereutectic aluminum.
Old Jun 21, 2004 | 06:15 AM
Can i still use the pistons if they have VERY small dents in them from hitting the valves? If they are not cracked that is.
Old Jun 22, 2004 | 02:34 AM
Moderator
Yep just sand off the sharp edges as they will get hot quicker thatn the rest of the piston and could cause detonation.
KamikaZ28
May 28, 2015 12:45 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
