Got my oil changed.. now the Change Oil light comes on
Old Apr 21, 2004 | 02:20 PM
PsychoJavexx's Avatar
The Change Oil light comes on when crank the car up. It only stays on for a minute or two, but I just got the oil changed in it, and there is enough oil in it. What's the deal?
Old Apr 21, 2004 | 02:24 PM
Omega9's Avatar
You have to reset it by turning the key 2 clicks, and then holding the odometer button in until the change oil light flashes.
Old Apr 21, 2004 | 02:58 PM
That's crazy man.. Thanks a lot!
Old Apr 23, 2004 | 11:03 AM
z28chrizz's Avatar
next time i am in my dash that bulb is coming out... i change mine every 3k... not when the car decides its time... it doesnt even know what kind of oil is in it!
Old Apr 23, 2004 | 09:28 PM
DanBUCF's Avatar
Yeah...the car's computer uses some sort of crazy algorithm to figure out when you should "theoritcally" need to change your oil. However, if you change your oil and forget to reset it, the computer has no idea that this has happened. This happens to me about every 7,000 miles or so I believe when I forget to reset the light.
Old Apr 23, 2004 | 10:47 PM
mullettour's Avatar
Supposedly you can turn the key to run and pump the accelerator pedal 3 times to reset it also. I haven't tried it so I don't know, but if it works it will keep you from reseting your trip meter if you like to keep track of gas mileage.
Old Apr 24, 2004 | 01:11 AM
Aneurysm's Avatar
Wierd thing is.. I've never reset my "oil life computer"... but its also never come on either. I have never seen the "Change oil" light. And I almost always change my own oil, the few times I dont, I am sitting in the car while it is changed.
I have a Canadian Camaro.. maybe the computer is a little different in these cars, I dunno.
Old Apr 24, 2004 | 03:31 AM
AL SS590 M6's Avatar
Moderator
They are all Canadian Camaros or Firebirds.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
jj71787
Jan 31, 2015 10:20 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
