Got a 02 WS6
Old Jul 15, 2005 | 07:40 PM
94zLT1's Avatar
Got a 02 WS6
Just purchased a 2002 trans am WS6 black on black.
41,300K 1 owner
got some questions. what oil should i use? 10W30 mobil 1? 5 quarts?
cant get the raditor cap off?
the ram air box and lid and intake look restrictive. what is a good upgrade?
also if someone could point me to a good tranny cooler install write up. as well as where to put the sending unit for a tranny temp gauge..
whats the best intake setup for me?
thanks
Old Jul 15, 2005 | 08:00 PM
94zLT1's Avatar
Re: Got a 02 WS6
i also put in 1/2 can of seafoam into my crankcase..im going to run it 2nt about an hr to work and change the oil 2morrow is this ok?
Old Jul 15, 2005 | 08:12 PM
97BBlackZ's Avatar
Re: Got a 02 WS6
41,300K 1 owner
Most people use Mobil 1 10W30. Also 5 quarts is what the manuel says i think but most put in around 5 1/2 to 6 quarts or just fill it till the dipstick reads full. Most LS1 tend to burn about half a quart of oil between each oil change.
Not sure on that one. Is there still pressure in the system maybe?
Most people go with an aftermarket lid. Some even cut out the brazel in the air box part as well.
Not sure on the last two but you might try LS1.com or LS1tech.com and search some of the forums for one and i'm sure you will find what your looking for.
Congrads on the car. I've always wanted a black on black WS-6 Just a pain in the *** to keep clean haha.
Old Jul 15, 2005 | 08:20 PM
94zLT1's Avatar
Re: Got a 02 WS6
thanks bud..think ill go MTI clear lid...can i cut the black piece of plastic behind the grills on the hood? whats the best filter? stock is filthy..green?
Old Jul 15, 2005 | 08:27 PM
Kataklysm's Avatar
Re: Got a 02 WS6
Paper air filters are the best. Any lid will offer the same performance. Use 5W30 motor oil.
Old Jul 15, 2005 | 08:31 PM
97BBlackZ's Avatar
Re: Got a 02 WS6
yea any air filter should work for you. I'm not sure exactlly which part on T/A thats you are suppose to cut but i think a quick search on ls1.com or something should bring something up.
I think there is something in the hood where the air goes in that you can cut out to. I think the peice in the air box is a black plastic peice that runs across in the middle of the intake where the filter sits is what your suppose to cut out.
Old Jul 15, 2005 | 08:34 PM
94zLT1's Avatar
Re: Got a 02 WS6
also i hear piston slap does it go away?
Old Jul 15, 2005 | 08:57 PM
97BBlackZ's Avatar
Re: Got a 02 WS6
Yes normally it goes away after the engine has warmed up since everything is alum. Some people on other boards have had luck with changing to a thicker or heavier oil so that might also help to.
Old Jul 16, 2005 | 10:50 AM
00Z28SS's Avatar
Re: Got a 02 WS6
Congrats on the ride. Now go have some fun.
Old Jul 16, 2005 | 10:55 AM
94zLT1's Avatar
Re: Got a 02 WS6
for thicker oil what do you suggest? thanks
HibachiZ28
Nov 6, 2015 12:53 AM
Stephen68
Oct 16, 2015 03:50 PM
95mysticta
Aug 20, 2015 07:43 PM
techstar
Aug 6, 2015 11:20 AM
Jlo
Jul 22, 2015 05:00 PM
