good head cam package
Old Sep 7, 2007 | 08:39 AM
CamaroSS77388's Avatar
i have a basically stock 98 ss. whats a good head and cam package for my car i dont want alot of power, since its a daily driver and something decent will work. i dont know alot of about heads and cams so can someone help me out. im not really worried about price but dont want anything outrageously expensive
Old Sep 7, 2007 | 10:27 AM
EDC's Avatar
EDC
Talk to this guy in Arizona...
Nic D - LS1 GTO
Old Sep 7, 2007 | 11:53 AM
teke184's Avatar
TR cheaTR cam with AFR heads $2560, with headers you'll see over 400rwhp
Old Sep 7, 2007 | 12:16 PM
Greed4Speed's Avatar
Get your bolt ons first.
Old Sep 7, 2007 | 09:37 PM
Michael943's Avatar
i didnt want a extreme cam/head combo that wouldnt be good as a daily driver and that would also require me to change out other internals
Old Sep 8, 2007 | 08:00 AM
What other internals? All cam changes require springs and you really should do pushrods and while there LS2 cahin and port pump if you want.
The more agressive cams just need springs more often, but my 226 grind has .590 lift and its been in over a year of daily driving w/out a hiccup.
Old Sep 8, 2007 | 10:52 AM
Kraest's Avatar
Retired
Hundreds of threads on this subject..............
Old Sep 9, 2007 | 02:07 PM
Michael943's Avatar
im stuck on the same subject, i want a good head and cam package on my stock ls1 but im looking for about 500 horsepower- would this be a good package-
F13 cam on a 112+4
AFR heads 61cc
Old Sep 9, 2007 | 06:06 PM
93v8clone's Avatar
not sure of there website butt cartek in new jersey has a couple good h-c packages
Old Sep 9, 2007 | 06:36 PM
Kraest's Avatar
Retired
F13 cam on a 112+4
AFR heads 61cc
Yes. That would be around 500-550 BHP depending on if you used a FAST 90/90 or not.
Which AFRs? 205cc? 225cc?
I'd do the AFRs to 59cc.
Mike
Old Sep 9, 2007 | 08:41 PM
Michael943's Avatar
i was thinkin 205
Old Sep 9, 2007 | 10:11 PM
Kraest's Avatar
Retired
205cc AFR Mongoose will work nicely. Is there any reason you want those heads besides the name? The Dart 225cc are cheaper and work just as well in my personal experience... .I made 471 rwhp with them and a FAST 90/90 with an F-15 112 +2.
Either way, you'd want the heads milled to around 59cc and use the .040" Cometic or stock GM gaskets depending on what compression you want. The .040" gaskets will give you a tight quench and the compression will be somewhere in the high 11s with the 59cc milled head. Perfect for a premium pump gas car.
Mike
Old Sep 10, 2007 | 07:17 AM
Michael943's Avatar
i just heard good reviews about them and seen many people use them on ls1's
Old Sep 10, 2007 | 01:22 PM
FifeDogg's Avatar
go to texas-speed.com and look at there head/cam kits. Great deal!
Old Sep 16, 2007 | 09:54 PM
Michael943's Avatar
F13 cam on a 112+4
AFR heads 61cc
do you think the stage 2.5 head cam package from texas speed will give me the same results with the magic stick 3 cam as the head cam package above
here the site from the head cam package http://texas-speed.com/shop/item.asp...d=203&catid=47
