GM differential fluid, yes or no?
Old Sep 25, 2003 | 11:06 PM
HtownZ's Avatar
i hear thousands of stories about GM differential additive, some good and some bad, i need some opinions, do i add fluid when i change my oil or not?????????
Old Sep 26, 2003 | 12:06 AM
camaro322hp's Avatar
if your manual says to use it, use it.
Old Sep 26, 2003 | 12:07 AM
zoomjrl's Avatar
i was told by someone on this board that if it says "synthetic fluid for limited slip", then you should be ok without the addative. So thats what I did, Its been about 7k miles since I changed the oil. Haven't had any problems that I know of.
Old Sep 26, 2003 | 12:26 PM
CODY BEHNKE's Avatar
Not all synthetics have the additive, it is only in there if it says it is. Some lubes just aren't limited slip friendly thats why some note for limited slip.
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
