Getting the LS1 hotcam.....
Old Feb 15, 2003 | 07:04 PM
6speedZ28's Avatar
Now before you all crap on me hear me out. I am a college student on a budget so $399 for the kit sits well with me. On top of that I would get hardened pushrods. I like the way it lopes with 112lsa. Sound clips can be found on www.ls1info.com . Not looking for an outrageous power source here. Just want to be able to say that I am cammed and roll into the campus car shows "loping". Can't wait to get my new "bumpstick". Any thoughts and opinions are welcome.
Old Feb 16, 2003 | 01:04 AM
stik6shift93's Avatar
Great deal and it seems its what you're looking for. If you where looking for an all out cam for power I defiently wouldn't recommend it. For some reason gm ran a split pattern on that cam and the ls1s respond a lot better to single pattern of reverse splits. It'll boost your power a bit and give you that lope you're looking for and at that price I say go for it.
Old Feb 16, 2003 | 05:35 AM
Zdriven's Avatar
Might be apples to oranges but, I had the Hot Cam in my
LT1. The specs are the same for the LS1 version. I think
you will like it! It sounded awsome and really brought my
LT1 to life. You might have to get some computor tuning
to take full advantage of it though.
Good Luck!
Old Feb 16, 2003 | 07:11 PM
2000LS1Z28's Avatar
Post
Well for what you want, the Hotcam is a great choice. Good price(including LS6 springs), good reliability, and quality power with an AWESOME lope. You can also keep your stock pushrods with this cam. Not sure about retainers and timing chain.
The only thing is, this cam will idle like crap in your A4 without good custom tuning. Even then, it might still be a problem from time to time. It was basically meant for M6's. Although there are some guys running it with their A4's and doing OK.
Mike
2002 M6 Z28
Old Feb 16, 2003 | 09:09 PM
My84Z's Avatar
how much hp does the hotcam usually give?
Old Feb 17, 2003 | 09:38 AM
TA2001's Avatar
hotcam output with lid,catback,hotcam
330/330
added the SLP lt kit ( headers ,cats ,y-pipe )
351/364
Hotcam has a great lope.. sometimes to much.
I have the trottle blade drilled to 15/64" and I
have a .022" spacer on top of the stock setting
of idle setscrew..
with M6.. I still have problems for about first 15
minutes.. till PCM can get smart..
common problems in summer.. stops with AC on
max..
MPG.. on my setup best 29.9 late at night
on way to florida 200 mile run at 75mph , cruise,
AC on..
I have 18K on my cam/spring no problems.
http://ls1info.com
Old Feb 17, 2003 | 03:05 PM
hrtbeat2's Avatar
What kind of time does it take on a 02 to change a cam out for a speed shop to do it? And when you say custom tuning, do you mean with a power programer?
Old Feb 17, 2003 | 03:38 PM
6speedZ28's Avatar
We changed a cam in my friends '99 SS on a Fri. night. We cracked the first bolt at 6:30pm and had it done and running at 2:30am on Sat. By custom tuning he means having the PCM shipped out and programmed or taking it and getting it dyno tuned. A programmer isn't going to help you with this much.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
