Gears??
Look on the driver side door or inside the glove box for the build sticker with codes. If you see GU2 you have 2:73 if you see GU5 you have 3:23. A good gear ratio to upgrade to is 3:73. Hope this helps.
Curt
Curt
Ditto ...
For the A4, changing the rear to a 3.73 ratio will really wake up your car. And, if you REALLY want to go fast off the line, do a 3.73 rear and a 3000 stall TC. If I still had the Z28, that's what would have been installed.
Ok i went out and checked the RPO's and i have the 2.73 gears which blows monkey *****. So i wanna do the 3.73 gears.....
Who is a good brand to go with and how hard is it to do? Any help is appreciated...I live in McHenry Illinois if there is anyone local around me
if you look at the shifter console and it has 1 2 d od n p than you have the performance rear axle which is 3.23 if it just says 2 d od n p than you have the 2.73. now if anyone knows for a fact that this isn't so please let me know because this is what i gathered from an article that i read awhile ago.
Originally posted by Black01_Z
Nope I have 1,2,d, od and have 2.73s
ChrisFrez
Mar 22, 2015 09:12 AM
