Fuel rail leak.... huge fuel leak..
Old Mar 11, 2009 | 12:23 PM
IRONFIST's Avatar
There is a massive fuel leak, pointed out with the arrow.
I lost a quarter tank of gas in about 15mins...
I got no idea how to fix this, or if I did something wrong when I took the intake off?
Any ideas?
Old Mar 11, 2009 | 01:16 PM
Marc 85Z28's Avatar
That arrow points to your #2 injector. Either the injector is cracked or the upper O-ring is missing or damaged. Did you remove the fuel rail when you took the intake off?
Old Mar 11, 2009 | 04:50 PM
IRONFIST's Avatar
Pretty sure it's an O ring problem, since it squirts out perfectly in a circle... how do I remove the injector? Anything special about fixing this that I should know?
Old Mar 13, 2009 | 07:47 AM
AL SS590 M6's Avatar
Moderator
Pull the fuel rail hold down bolts and wiggle it up. It should come up with all the injectors attached. You can't remove it to far as all of the wires are still hoooked as well as the fuel lines. But it should come up enough for you to remove that injector to replace the o-ring.
Old Apr 2, 2009 | 08:00 AM
89385formula's Avatar
I know this thread is a few weeks old, but wondering if u got it fixed yet. In that picture the clip that holds the injector into place is missing, its a good possibility that the injector popped down to where the O ring would but in the flaired section of the fuel rail....thus no longer keeping a seal. Hope that helps!
Old Sep 3, 2011 | 08:28 PM
EagleOne's Avatar
Re: Fuel rail leak.... huge fuel leak..
It looks to me as if the fuel leak is where the injector engages with the fuel rail...
Old Sep 3, 2011 | 11:01 PM
johnny6's Avatar
I'm sure the 2+ year old leak has been fixed for a long time.
ad356
Apr 16, 2015 05:38 PM
dfarr67
Apr 10, 2015 07:44 PM
4586
Feb 13, 2015 09:16 AM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
