Fuel Injector Question
Will 2003 Corvette injectors work in an LS1 fbody application?
From my understanding the injectors in 2003 are Gen 3 Bosch. Are they any different than the normal LS1/6 injector from 1997-2002?
Bosch part #0 280 155 931
GM part #12561462
Thanks in advance, hope somebody knows this one.
GM part #12561462
I actually got them to use in an LT1 and they work great! The pressure rating of them pretty much equals out so that isn't an issue. The only problem that I have run into is that the LT1 fuel rail injector clips don't work so hot because the LS1 injectors dont have a groove all the way around for the clip to seat into. If that makes any sense.
Anyways, the throttle response is a lot better than it ever has been so I am happy.
What kind of clips do the LS1 cars use to hold the injector in place? Is it a similar setup as an LT1 or what? Anybody have any pictures?
Jul 4, 2005 05:00 PM
