Flowtech slip fit cutout from Summit got ?'s ...
Old Dec 13, 2003 | 07:01 PM
z28chrizz's Avatar
Does anyone run this cutout? I was just wondering about the install... slip fit means no welding right? Factory I pipe goes inside cutout on both sides, then drop some muffler clamps on top? Does anyone know?
Figure 50 bucks for the slipfit one vs 30 for one I have to have welded seems like a decent deal. The exhaust shops around here all seem to be tight a$$es with the whole modifying exhaust systems (illegal in NY)
Link to Product pic and description...
Also assume I would need the 3" unit right?
Did a bunch of searches but didnt find anyone using this unit.
Old Dec 13, 2003 | 07:47 PM
TxAgZ28's Avatar
Don't know about slip-fit, but I assume they mean it to install as you say, with muffler clamps.
I got the $26 Summit brand one and had it welded in. Works just fine But the install cost $30, soo...
And yes, you need 3" size.
Old Dec 13, 2003 | 11:23 PM
teke184's Avatar
i highly doubt it will install as easy as you say it will
first off, the stock pipe is 2.75" so that's a quarter inch you'll have to make up...no way clamps will do that without leaking.
you're gonna have to have it welded if you want a decent job on the install
Old Dec 14, 2003 | 12:59 AM
z28chrizz's Avatar
Is that 2.75" OD or ID? (too lazy to go lay on the 15 degree pavement and measure) If it is ID, then a 3" pipe should slip over no? They also make a 2.5" setup, although going smaller doesnt seem like a good idea to me.
To slip fit it, I would have to drop the rear section of pipe after cutting, and slide it back to get this on the I pipe.
My looking for an alternate solution isnt being cheap so much as I really called around to about 5-6 places and noone was interested in welding a cutout in for me. Not even afterhours for cash...
Old Dec 14, 2003 | 10:54 AM
teke184's Avatar
i think it's 2.75 outside diameter....
i think you're stuck....
DirtyDaveW
Dec 1, 2016 05:37 PM
Redbird
Jul 20, 2002 06:08 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
