Firebird Formula VS Z28 SS (2002's)
Originally posted by codyman16
the ss hood scoop does work as a cold air intake and works even better at high speeds. I know i can hear my scoop and it gets louder as speeds increase. I Have heard of many z28's adding the scoop and getting better 1/4 mile times than before
Originally posted by psychocabbage
i never heard of that... ever.. and i am on alot.. i hear the opposite as most SS owners go to lids and CAI
btw adding cai and lids are a good idea too, the more air the better, they all work well with each other
I have a Suncoast Creations SS hood on my Z28. It is about 10 pounds lighter than the factory hood, but there is no performance from the scoop. I ended up getting a FTRA and selling the SS airbox stuff. They look great, but I wouldn't get too hung up on the performance value.
Isn't this topic allready going?
#1- A standard Z28 came with T rated Eagle GA tires
#2- It is very obvious the SS hood works
#3- I would rather pay the extra $ and have a SS than a Z28
#4- The SS and Formula weigh within 30lbs of each other
#5- The WS6 is not the same as a SS the Firehawk is
Put your hand by the hood scoop and have someone rev it up.
Originally posted by 99blackSS
Good enough?
Good enough?
If you tell me those specs are for 2002, I'll believe you.
Another member was telling me the Bilsteins were standard on the 98 SSs
Z28 adds/changes
front springs: 292 lb/in (49 N/mm)
front sway bar: 30mm (tube)
rear springs: 114 lb/in (20 N/mm)
rear sway bar: 15mm
Z28 adds/changes:
16x8 cast aluminum painted wheels
P235/55R-16 touring tires
SS adds/changes:
17x9 cast aluminum painted wheels
275/40ZR-17 Goodyear F1 tires
front shocks: deCarbon 46mm
front springs: 360 lb/in (63 N/mm)
front sway bar: 32mm (tube)
rear shocks: deCarbon 36mm
rear springs: 130-180 lb/in (23-32 N/mm)
rear sway bar: 19mm
SLP Y2Y Bilstein option (not available on the SS convertible) adds/changes:
front shocks: Bilstein B46-2071 46mm (with special SLP valving)
front springs: Eibach 300-450 lb/in (53-79 N/mm)
rear shocks: Bilstein B46-1914 46mm
rear springs: Eibach 115-185 lb/in (20-32 N/mm)
stiffer rear lower control arm bushings
Good enough?
Z28 adds/changes
rear sway bar: 15mm
Z28 adds/changes:
SS adds/changes:
rear sway bar: 19mm
Good enough?
Originally posted by Freak
I dont know where you are getting your information from, but I would check it If I were you. I have a standard Z28, and my rear sway bar is most certainly NOT 15mm. it is, in fact 19mm.
Jan 13, 2015 09:52 PM
regular Joe
Aug 10, 2002 07:15 PM
