Finally got my block back..........
Old Apr 11, 2008 | 11:46 PM
mrpittbull's Avatar
I've felt like Katt Williams in American Pimp the last 3 wks,(Wait for it Wait for it) But I got my heads and block back today. Now I need a set of LS2 valve covers. Does anybody make aftermarket covers or am I gonna have to go dumpster divin? And any trouble with the coil packs going on them? But... I have the rest. I think. 10 over block;coated pistons;MS3 cam and install kit; Pacesetter LT's with neweraperf. 3" Y pipe;Ram Suregrip clutch;LS2 timing chain;LS6 oil pump; 'puter tuned bt TSP. Hopefully it will all turn out pretty good. any info about the covers would be appreciated.
Old Apr 15, 2008 | 10:47 AM
ss.slp.ls1's Avatar
Wish I could help you with the covers...sounds like a nice set up, I have heard the MS3, I like it a lot. Good luck.
Old Apr 15, 2008 | 11:36 AM
Marc 85Z28's Avatar
Why do you think you need "LS2" valve covers?
And if you're still using your stock 98 coils, you have no choice but to stay with the 97/98 LS1 valve covers.
Old Apr 16, 2008 | 12:39 AM
mrpittbull's Avatar
LS2 heads
Im putting a set of LS2 heads on . Thats why I need the covers. They are centerbolt covers and the Ls1 is a perimeter bolt. I found a set on ebay and Im going to bid on them I guess if I cant find them locally. Thanks for the info.
Old Apr 16, 2008 | 08:13 AM
Marc 85Z28's Avatar
LS2 heads use the same centerbolt valve covers that the 99-04 LS1 uses. Only the 97-98 LS1 had perimeter bolt. Just get a set of centerbolt LS1 covers. You'll need the 99+ ignition coils too, as your perimeter valve cover mounted coils will not work with the later style valve cover.
Old Apr 16, 2008 | 08:35 AM
ss.slp.ls1's Avatar
That's what I was thinking.
Old Apr 16, 2008 | 10:28 PM
mrpittbull's Avatar
Valve covers
I got a set of valve covers. The local Chevy dealer said they could order a bracket to mount my coils onto the LS2 covers. Is this possible or are they tryin to make quota for the month? On a good point, the motor is together and bolted to the suspension and fixin to go back in
Old Apr 17, 2008 | 01:21 PM
Marc 85Z28's Avatar
You can make the 97/98 coils work with a 99+ coil bracket.
TitoPR221
May 26, 2015 12:20 AM
KYWes
May 22, 2015 08:48 PM
C6LS3
Apr 15, 2015 09:50 AM
madman69
Aug 18, 2002 03:58 PM
Dragonballz28
Jul 25, 2002 03:19 PM
