Finally did the TB coolant bypass
Old Aug 27, 2007 | 08:30 AM
km9v's Avatar
It took a little longer than I thought it would. The passenger side hose came off easily. However, the driver side hose had to be cut off b/c it was stuck. Had to make a quick trip to AZ for some new hose. I even had to cut the other side of the hose that connects to the coolant intake tube. I guess it got pretty hot over the yrs. Anyone else have this problem?
Old Aug 27, 2007 | 05:19 PM
moroso99's Avatar
no problems at all with mine, took ten minutes.
Old Aug 28, 2007 | 06:58 PM
Snugans310's Avatar
i did it the easy way i just got the plugs and got a whole new hose one piece and cut out all the old one and put the new one tool like 10 min
Old Aug 28, 2007 | 08:31 PM
reocamaro's Avatar
While we're on topic, what is the significance of this mod?
Old Aug 28, 2007 | 08:39 PM
moroso99's Avatar
supposedly its to keep the throttle body cooler. with out the hot coolant flowing through the tb the air in the tb doesnt get as hot. im sure its only a few degrees, but every little bit counts.
Old Aug 29, 2007 | 09:28 AM
km9v's Avatar
After I finished this mod, I wondered why not just replace the whole hose?
Old Aug 29, 2007 | 09:30 AM
km9v's Avatar
This mod significantly reduced the temp of the TB. After driving 20 mi. it was just warm to the touch. Before the mod, it would burn my finger. I do feel better throttle response.
Old Aug 29, 2007 | 04:36 PM
pitbull14218's Avatar
what size hose and other parts you use, i still need to do mine but i want it to looks very nice. and dont you get air in the line from doing it? I know it cant be too much could it effect anything? sorry i dont know everything. thanks
Old Aug 30, 2007 | 03:46 PM
I finally did it too, just yesterday. i used a vacum line adapter 5/16 to 1/4 do you think it is safe? it is plastic but the guy at advanced said its ok because so is the resovor that has the coolant in it. so i figured he might be right. when i was putting the hose on the 1/4 side i didnt wet the adapter and tried to twist it on and the plastic peice twisted alittle but it isnt leaking or anything. its not like it will melt right? just wanted to know if it should be fine. thanks.
Old Aug 30, 2007 | 04:03 PM
km9v's Avatar
I bought the kit from BMR. It has an aluminum connector.
Old Aug 31, 2007 | 06:46 AM
AL SS590 M6's Avatar
Moderator
The guy at Advanced was wrong as usual. The TB coolant mod has nothing to do with the resevior. This is the hot coolant from the heads to the radiator. Go to a hardware store and pay the buck or so for a brass hase barb adapter.
Old Aug 31, 2007 | 08:43 AM
NemesisLT1's Avatar
I used a brass barb connector, and two plugs.... really easy mod.... except on LT1's lol
Old Aug 31, 2007 | 09:16 AM
km9v's Avatar
http://www.bmrfabrication.com/F-bodyPerformance.htm
Old Aug 31, 2007 | 03:56 PM
ok thanks. yea i would rather play it safe. thanks again it didnt leak yet but it could eventually, thanks.
Old Aug 31, 2007 | 04:09 PM
maro69camaro's Avatar
so are the lines 5/16 & 1/4 just want to know so i can get the parts and do it.. thanks
