Few cam questions...
Old Apr 10, 2007 | 01:26 AM
jshelton2006's Avatar
02 SS, LS1, M6, Pacesetter LTs, O/R Y, GMMG, whisper lid, k&n, smooth bellow, ASP pulleys, SLP MAF, stock gears
Next mod is a cam with stock heads for now, but not exactly sure what one...the car is my daily driver, but i want as much performance out of it as possible. I want power from low to about 6000 rpms, i dont want to have to rev the hell out of it just to get a little more power...ive looked at the Futral F13 112 LSA and Thunder Racing 224/224 112 LSA, but im not sure. the F13 seems like it will make power too high in rpm range for my liking (2500-6800rpm), will this kill low end? but i dont know it the 224/224 is aggressive enough for what i want either. I want a rough, awesome sound at idle and great performance. Eventually i will put heads on it, but i dont want that to influence my decision a whole lot because i have no idea when i'll get the money for them. I understand some cam basics, but i just need a little help with my decision. I think a 112 LSA is what i want...also these cams will have enough piston-to-valve clearance, right? i will also have the computer tuned. thanks a lot for all your help, if ive left anything out just tell me...thanks!!
Old Apr 10, 2007 | 02:25 AM
Bayer-Z28's Avatar
The only cam you have to worry about PTVC is the TRex and MS4. .650 lift, basically.
I'd say the f13 is a good looking cam. It was on my list for a while. I'd say a TSP Torquer V2 or f13 @ 230"/232" .595"/.585" 112LSA. The 114's have a wider powerband.. either that or the milder cams w/ 113 or greater LSA.
Old Apr 10, 2007 | 07:34 AM
Greed4Speed's Avatar
Personally, I'd think your next mods should be suspension related. You can make great power, but if you can't put it down...........
Old Apr 10, 2007 | 07:48 AM
teke184's Avatar
due to the nature of the lsx engine and the nature of a cam....it's hard to make all your power below 6000rpm.
you could go with something like the TSP 228R (228/228 .588/.588 112 or 114). they say 1700-6300 rpm range, and the XER lobes should make good power. and with a slightly more conservative lift you won't have to worry about ptv clearance, even with milled or big valve heads.
Old Apr 10, 2007 | 10:50 AM
Kraest's Avatar
Retired
Next mod is a cam with stock heads for now, but not exactly sure what one...the car is my daily driver, but i want as much performance out of it as possible. I want power from low to about 6000 rpms, i dont want to have to rev the hell out of it just to get a little more power...ive looked at the Futral F13 112 LSA and Thunder Racing 224/224 112 LSA, but im not sure. the F13 seems like it will make power too high in rpm range for my liking (2500-6800rpm), will this kill low end? these cams will have enough piston-to-valve clearance, right? i will also have the computer tuned. thanks a lot for all your help, if ive left anything out just tell me...thanks!!
The F-13 typically peaks around 6000 RPM, but it doesn't drop in power until well past 6500 rpm. There's no reason you can't shift it at 6200 to be "safe". The F-13 isn't big enough to kill your low-end, in fact it makes lots of torque low for great streetability. There's enough valve-clearance to put some .030" milled heads on top of it, so there's definetly enough valve-clearance to put the stock heads back on.
The 224 isn't going to be enough cam for most people's liking. It's a mild cam that boosts performance, but there are many grinds out there that outperform it.
rideordie
Nov 5, 2019 04:52 PM
blkWidow
Apr 20, 2015 09:27 AM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Nov 20, 2014 06:03 PM
