Fan Switch: Removing the PCM
Old Sep 6, 2003 | 04:06 PM
Flat_Tire_'s Avatar
Hey just got my slp fan switch in the mail .. Took a look at what needs to be done and as suggested I'm supposed to remove the PCM to get access to a hole that goes through my firewall .. Anyone have detailed instructions on this seciton of the install? Or possibly even pics?
Old Sep 7, 2003 | 12:10 AM
Ferocity02's Avatar
Phffff..... Removing the PCM is for suckers. Get a flashlight and shine it at the firewall to the left of the PCM and you will see the hole. Get a coat-hanger, make it into a hook and put it through the hole, hook the wire onto the end of the hanger, and pull through! Super easy!
Old Sep 7, 2003 | 12:23 AM
ULTIMTEORANGESS's Avatar
hes right.no need to remove it.itll fit thru the firewall.just cut the grommett enough so the wire will fit.
Old Sep 7, 2003 | 01:02 PM
BigBlackZ28's Avatar
You don't need to remove it, just move it. Unbolt the bracket that holds it in place and move it to the side. Should be able to access it very easily.
Oh and that hole leads to the glove compartment then out under the dash. Open the glove compartmnent, take everything out, then squeeze btoh sides of it and it will swing down giving you access to the BCM. After feeding the wire, you should be able to see it from there.
DirtyDaveW
Dec 1, 2016 05:37 PM
jayvar
Feb 2, 2015 10:00 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
97SSdude
Dec 31, 2014 07:43 PM
Jul 4, 2005 05:00 PM
