fan switch mod
Old Aug 9, 2003 | 05:19 PM
2000zee28's Avatar
fan switch mod
I did a mod that turns the cooling fans on with a toggle switch.
I tyed into the light blue wire under #1 fan relay. Is there a way to tye into high speed fans instead. Will I only see a difference in lower cooling temp when I install and 160 t-stat? Or will the fan mod work alone? Thanks Ron
Old Aug 10, 2003 | 12:59 AM
LS1-Maniac's Avatar
You probably need the 160 stat and the fan switch together to get the best results. I don't think you fans will keep the engine cooler than 210 without the aid of the t-stat. The fan switch is more for when your engine is off and your waiting in line at the drag strip.
Old Aug 10, 2003 | 08:33 AM
9T8W66's Avatar
I have the SLP fan switch and it does work without the T-stat.
It also has high and low settings though, on a very hot day engine temp stays at 170-175 (on the gauge).
Old Aug 10, 2003 | 08:57 PM
mooleyz28's Avatar
I like the idea of the fan mod but i cant seem to find it anywhere if u could please e-mail me the setup and steps on how to do it. i would be more than happy to thank u 1000 times. so if u happen to know how to do it or where i can find out how to do it. please contact me at "borderpolice07@aol.com" thank you. Mooley
Old Aug 10, 2003 | 10:39 PM
2000zee28's Avatar
This is the procedure I used: http://www.fbody.com/members/safbody/faq/coolfan.htm
I used a wire splice on the LT. blue wire under #1 fan relay instead of pulling the fuse box out. I routed the 14ga wire up the way outlined and then slipped in under the door seal and behind the kick panel. I put a switch under the dash panel below the steering wheel. I have had 2 guy's with Mustangs looking at my car ask me where the N20 was hidden. Who would think you could have so much fun with a $2.00 single poll switch! Ron
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Sep 13, 2002 03:35 PM
troywg
Sep 12, 2002 07:28 PM
sfGi8nt
Aug 1, 2002 05:54 AM
