Exhaust pipe kinked, cant slide another section thru
Old May 14, 2006 | 07:17 PM
pHEnomIC's Avatar
Here is a pic to make explaining a bit easier.
I have a dynomouth exhaust/tsp rumbler. There is a clamp after the muffler that connects the rear section. Someone in the past tightened the clamp that holds these two pipes too much and the pipe kinked inwards. I had trouble with this section before but was lucky and got it in there perfect w/o any problems. I got it temporarily held together with the clamp that was on there, the standard type of exhaust clamp but it will slip out eventually.
Basically, the pipe on the outside is kinked so I cant slide the inner pipe in far enough to make an effective clamp with the standard type.
Is there any way to join these two pipes together so that it won't come undone? I do not want to weld because I would like to make this part disconnectable in the future.
The pipe isn't kinked enough to hurt airflow but it is bad enough that I can't slide the front pipe through enough.
Old May 14, 2006 | 07:56 PM
doug1105's Avatar
Re: Exhaust pipe kinked, cant slide another section thru
Go to advance/autozone and get an exhaust pipe expander loaner tool.
You stick it in the kinked pipe and turn the nut on the end, and it will expand the kinked part out so that its back to normal.
Victor Lamb
Aug 26, 2017 02:52 PM
drptop70ss
May 4, 2015 08:22 PM
carl.froehlich
Mar 13, 2015 12:38 AM
MadMav
Feb 6, 2015 11:02 PM
Collector Car
Jan 5, 2015 10:58 AM
