everyone with cutouts post here.
Old Oct 23, 2003 | 03:03 PM
CableWS6's Avatar
hey guys i jsut had to get a new catalytic converter and the guy at dealership said it could have been caused by my cutout being open. everyone with cutouts please post and tell me how long u have had ur cutout open and if u have had any problems. thanks
Old Oct 23, 2003 | 03:09 PM
Aklaim's Avatar
I have thrown bad catalyst codes, and I drive around with my cut out open all the time. A buddy of mine runs a speed shop and he told me its from having my cut out open all the time. And its probobly not the cat, but more likely its the 02 sensor. when you have the cut out open all the time it can suck in cold air, which messes with the 02's.
Old Oct 23, 2003 | 03:29 PM
95GRNZ's Avatar
Question
Unless your cutout is installed on the Y-pipe, before the cats, I don't see how a cutout could mess up your cat?
TS
Old Oct 23, 2003 | 04:04 PM
2001NBMZ28's Avatar
I run around with mine open most of the time (installed under the back seat) - never threw any codes. A bad cat will throw code 0420 or 0430 depending on which bank it is. I see alot of posts on bad cats on 2000/early 2001 models. A friend of mine just had his driver's side cat replaced (0420) without a cutout at 22K miles.
Old Oct 23, 2003 | 04:21 PM
Mikie's Avatar
Why dont you just get you two 02 simms and forget about the cats all together?
Old Oct 23, 2003 | 04:23 PM
96 TA's Avatar
Ive never had a problem with mine. I don't see how you could have a problem! But then again I do have O2 sims.
Old Oct 23, 2003 | 06:22 PM
CableWS6's Avatar
can someone explain to me wut O2 simms are and do. and are they easy to install. i looked em up on thundracing but it dint tell me what they do thanks. sorry im illiterate
Old Oct 23, 2003 | 06:35 PM
Mikie's Avatar
They are small plug in modules that trick the 02 sensors into thinking that all is kosher in smogville.
Lots of people want to gut their cats or run off-road pipes without converters and on OBDII cars it will trip a check engine light. Buy the O2 simms , normally called Mil Eliminators and plug them into your rear O2 sensors and you wont have any more problems.
In my opinion they are a butt load cheaper than new converters.
click here...>>> www.casperselectronics.com
Later
Mike
Old Oct 23, 2003 | 07:23 PM
99BlackZ28T56's Avatar
I've had my cutout open for over a moth now without problems. But then my car came with O2 simms and I have programming that got rid of the codes so I don't need the O2 simms anymore.
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
ProudPony
Aug 29, 2002 04:20 PM
JasonD
Jul 15, 2002 02:17 PM
