ES transmisson mount torque arm bushing
Old May 9, 2003 | 07:51 AM
sweet98ss's Avatar
I have a 98 ss with the m6. I just recently put the Energy suspension transmission mount and torque arm bushing in. This should be high on the list of first mods. What a difference it made on my car. Made it feel alot tighter. The only question I have is it vibrates at highway speeds. I saw all the stuff about removing the preload plate and grinding the bumps down and putting washers under the crossmember. I have already put 1000 miles on it and it still does it. Should I modify mine. I dont mind the extra noise, its just the vibration. Im going to the track tomorrow and want to know if it will hurt if I dont do it before the track..
thanks
Old May 9, 2003 | 07:58 AM
psychocabbage's Avatar
ever hear of a smooth running race car? You have essentially stiffened up your tranny to car mount.. so why wouldnt it transfer more of the vibes now?
Its totally normal.. I used to run the ES bushings.. I like them but with my 2002 (i had a 1995 before) I want a plush ride for a while..
Maybe later on I will start with the mods.. I would also suggest that ya get an Airlift airbag and mount it in the right rear spring.. At the track, inflate to about 22psi.. preloads the right rear giving you a better launch.. for $35 its not a bad deal but you do need to go halfsies with someone as they sell them in pairs..
Old May 9, 2003 | 08:07 AM
1fastV6's Avatar
i was told to give it a while - it will smooth itself out. and no it shouldnt hurt you at the track.
Old May 12, 2003 | 02:20 PM
2MCHPWR's Avatar
I removed the preload plate and grinded the bumps down and didn't use any washers under the crossmember. no vibrations really. love it.
Old May 12, 2003 | 02:40 PM
sweet98ss's Avatar
Mine is actually starting to get better.........Ill try if it doesnt go away........thanks
Old May 12, 2003 | 02:59 PM
CPFarhood's Avatar
Mine shakes the change right out of my ash tray and i love it
Old May 12, 2003 | 04:08 PM
PhantomTA's Avatar
Moderator
It doesnt go away.. you just get used to it.. stop whining or go buy a caddy instead
Old May 12, 2003 | 04:30 PM
stik6shift98's Avatar
mine went away a little bit but the vibration is with you from now on
Old May 13, 2003 | 07:11 AM
sweet98ss's Avatar
Im not whining .........I just wasnt sure if it is normal for my whole console to shake like that.................
Old May 13, 2003 | 11:40 AM
ls1camarogal's Avatar
I have the ES transmission mount & torque arm bushings too. After installing the tranny mount, I had a wonderful vibration although it's not so noticeable anymore. I love it!
KYWes
May 22, 2015 08:48 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
