engine swap questions
Old Aug 25, 2012 | 03:52 PM
eric587's Avatar
i want to put a modern engine in my 68 camaro because i like the look of them and the increased power but i am on a budget what would you guys recommend i dont need the top of the line engine i just want a good looking engine and what would you recommend and why? thanks
Old Aug 25, 2012 | 10:56 PM
97z28k&N's Avatar
lt1's are cheap, but I don't know what you think looks "good". ls1's look good too, but they're much more expensive.
Posted from Camaroz28.com App for Android
Old Aug 26, 2012 | 02:55 PM
eric587's Avatar
Re: engine swap questions
how much would a lt swap generally run
Old Aug 26, 2012 | 03:44 PM
97z28k&N's Avatar
it depends if you are doing it or a shop is.
Old Aug 26, 2012 | 09:53 PM
green96ta's Avatar
You can buy a 5.3 truck motor if you look for under 1k with a trans usually. Then just put a ls1 intake on it and you have a iron block ls1 just with 5.3 ci. or you can do a 6.0 truck motor but people usually want an arm and a leg for those. When it comes time for a stand alone harness give me a message ill help you out with that.
rocketman051894
Jan 30, 2015 03:23 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
squirrels
Jul 13, 2002 01:58 AM
