engine swap ls1 to a 6.0
I have a 98 z with a bad motor and I want to put a 6.0 in it or a ls3 what do I need to change to make everything work like it is supposed to? Or can you reflash the computer and make this work.. Thanks for your help
Re: engine swap ls1 to a 6.0
im in the same boat i have a 2002 z28 blew a hole in the block right above the starter something in the bottom let go i guess...so i need to know if i can get an LQ9 motor and put all my accy's on it and if i need the ecm and harness from the LQ9 or can i use my LS1 ecm and harness? thanks..
You will need a conversion kit to run the 58x crank signal our cars is 24x.
The front cover is different ect. ect.
You can get the kit from Scoggin Dickey Performance.
i thought 02-06 LQ9's were 24x.....when you say front cover is different do you mean the timing cover? can i use the one off my ls1?
Jul 4, 2005 05:00 PM
