engine removal
Old Apr 7, 2010 | 06:40 PM
oldone's Avatar
engine removal
hi all new here. well any way i need advise on how to remove engine out bottom. i read here some where that a member posted all the how to with pics. or any advise will help going to do it in 2 weeks thanks
Old Apr 7, 2010 | 06:48 PM
oldone's Avatar
well i looked around here its already been answered sorry my bad all that has me worried is wiring on pass fender all that stays with motor out bottom?
Old Apr 7, 2010 | 08:19 PM
johnny6's Avatar
The engine to chassis wires need to come off, disconnect the PCM harness and you should be good to go as far as wiring is concerned. Mine came out the top but everyone has their preference.
Old Apr 8, 2010 | 07:37 AM
AL SS590 M6's Avatar
Moderator
Yep just un plug any wires on the fender that are hard wired into the PCM plugs and throw them on top of the motor. That includes pulling the PCM out of the way and the passenger kick panel to get to the plugins inside the car, there's only a couple of wires going in there.
Oh and the most important thing is to take tons of pics for reference on re-assembly.
Old Apr 8, 2010 | 08:46 PM
oldone's Avatar
fuel lines
is yhier a tool that takes off the line next to pressure line i have one for pressure line thanks oh and any special way to bleed anti lock brakes
Old Apr 8, 2010 | 11:53 PM
ald9351's Avatar
The tool for the return is just like the pressure, just the next size smaller.
Just make sure to keep the master cylinder full while bleeding.
Old Apr 8, 2010 | 11:59 PM
Meatyshells's Avatar
not sure what your plans are, but i found it easier to just unbolt the ac compressor off the engine so that i wouldnt have to mess with it, then just installed it on the new engine
Old Apr 9, 2010 | 06:33 AM
Moderator
No fuel return line on an LS1 f-body, thats the line for the fuel vapor recovery system. The end that hooks to the valve on the motor is just a squeeze it with your fingers type connector.
Old Apr 9, 2010 | 07:54 AM
soul strife's Avatar
This link as a ton of info including engine removal
http://www.bowlingss.com/LS1_How_To.htm
Old Apr 9, 2010 | 07:28 PM
oldone's Avatar
hey thanks guys. i tried to pull it off but dident want to break any thing . its the one that goes in like a little scelinoid and then in front of intake. it is taped to fuel line just before fuel rail.
Old Apr 10, 2010 | 05:59 AM
Moderator
The lock tab has 2 solid sides and 2 open sides. Pinch the solid sides with your fingers until they touch the tube, then wiggle it loose and off.
DirtyDaveW
Dec 1, 2016 05:37 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
centric
Aug 15, 2002 09:04 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
