engine removal
engine removal
hi all new here. well any way i need advise on how to remove engine out bottom. i read here some where that a member posted all the how to with pics. or any advise will help going to do it in 2 weeks thanks
Oh and the most important thing is to take tons of pics for reference on re-assembly.
No fuel return line on an LS1 f-body, thats the line for the fuel vapor recovery system. The end that hooks to the valve on the motor is just a squeeze it with your fingers type connector.
hey thanks guys. i tried to pull it off but dident want to break any thing . its the one that goes in like a little scelinoid and then in front of intake. it is taped to fuel line just before fuel rail.
The lock tab has 2 solid sides and 2 open sides. Pinch the solid sides with your fingers until they touch the tube, then wiggle it loose and off.
Mikes 1994 z28
Nov 25, 2014 02:00 PM
centric
Aug 15, 2002 09:04 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
