engine missfire??
Old Nov 6, 2004 | 01:43 PM
99 z28 Haas's Avatar
engine missfire??
alright a while back i threw a SES light and i scanned the car and got a engine missfire code. i ereased the code. its been about 3 months and the code just came back. what will i most likely have to replace to correct the missfire. the code was p0300. i wanna get it checked out and fixed before and real damage is done. thanks in advance.
Old Nov 7, 2004 | 12:51 AM
CrippleFightin's Avatar
Re: engine missfire??
Have someone with a good scanner check and see which cylinders are misfiring and how badly. Did you happen to down shift too much while driving or while going to fast? Because if all the cylinders are misfiring and one or more really badly, you could have some bent valves. (Worst case scenario) Also it could be a plug, wire or coil pack.
Old Nov 7, 2004 | 02:12 AM
1quick1's Avatar
Most likely just something like your plugs, wires, or coil. Definetly have it rescanned and start with that stuff.
Old Nov 7, 2004 | 03:21 AM
AL SS590 M6's Avatar
Moderator
First you need to tell us what car, year, mileage, mods.
Old Nov 7, 2004 | 03:53 PM
its a 99 z28 m6 with about 69k on it. i have a lid, LTs, open y-pipe, pushrods and rocker arms, cam, and suspension work. i cant really remember if i downshifted too much. i will get it scanned to see wich cylinders are missfiring. thanks for all the help fellas
edman
Mar 13, 2015 09:39 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
OneBad98Z
Aug 6, 2002 03:23 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
