eliminating slip regulator
ASR switch on the dash turns it off. "ASR Off" will let you drive hard. There is a reversal module you can buy to turn it off when you start the engine , then you can turn it on with the button. You will like ASR in loose traction conditions like wet roads, mud or snow. Also here is a cool site for your new ride. http://www.bfranker.badz28.com/
He is a member on this site too.
Click on 4th gen mods or the fix-it guides, tons of good info there.
Later>>>>>
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
