Electric water pump worth the $$$
Old Sep 13, 2004 | 12:02 PM
  #16
Drew778/94Z's Avatar
Re: Electric water pump worth the $$$
Thanks, I had the SSF 3500 sitting here for 6 months and finally got off my *** to put it in.
The car feel stronger, I'm going to take it to the track this weekend, I might try taking off the front sway bar off too.
Old Sep 13, 2004 | 01:01 PM
  #17
psychocabbage's Avatar
On my LT1 I did the water pump.. Wasnt happy. Was plagued with cooling issues afterwards. I think since mine was a daily driver and I regularly cruised at 80-95mph with 3.73's on an A4 and my RPMS were holding at about 3K it was not flowing enough coolant to do the job where a mechanical waterpump would go with the engine rpms..
Old Sep 13, 2004 | 10:05 PM
  #18
unvc92camarors's Avatar
hey psychocabbage, what was your pump rated at?
i think earlier in the thread it was mentioned that the stock pump flowed 25 at 6000rpms or something whereas the one he bought was like 35 all the time (all rpms)
i wouldn't think you'd have a problem since it flows more all the time
just trying to get info on this but i would probably stay with the stock one myself if it went (as in, replace it with another stock mech.)
Old Sep 13, 2004 | 10:28 PM
  #19
from the specs I remembered it outflowed only at idle.. didnt say specs for it otherwise.. was a mezzarie (sp?) pump for LT1..
that experience just made me shy away from them all together..
Old Sep 14, 2004 | 05:00 PM
  #20
yea, i thought it flowed less at high rpms than a stock one but the other guy pointed out that his should or did flow more
yea, they definately can be finicky though, especially with the guy on the lt1 boards that was stuck when his relay went or something
Old Sep 14, 2004 | 05:23 PM
  #21
Super Slow '97's Avatar
Never ha a problem with mine at all rpms cruising on the high way or sitting in traffic.
Old Sep 14, 2004 | 06:16 PM
  #22
ULTIMTEORANGESS's Avatar
for over $600 and 2 RWHP id have to say its not worth it.
thats what GMHTP gained on their ls1 with it.
Old Sep 14, 2004 | 10:54 PM
  #23
They also said the car ran at 150* after the install and thats worth some HP right there.
If a good deal comes up I might pick one up.
Old Sep 15, 2004 | 01:02 AM
  #24
LSUxBlake's Avatar
They dyno tested it in the GMHTP this month and it put down about 2/2.
Old Sep 15, 2004 | 04:28 AM
  #25
AL SS590 M6's Avatar
Moderator
There is another advantage to having an Ele.WP. You can run it with the motor off for that quick cool down between passes.
Old Sep 15, 2004 | 12:26 PM
  #26
If they were $300 I'd have one already, but $500+
Old Sep 15, 2004 | 02:49 PM
  #27
it still doesnt justify a $600 price tag.at least to me it doesnt.
Old Sep 16, 2004 | 07:39 PM
  #28
Moderator
Shop around. I paid less than $500.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
