View Poll Results: Go BOOOSTED or go BUILT!! Which one?
SUPERCHARGED (procharger or Vortech
35.71%
BUILT (heads/cam/pulleys/manifold
9
64.29%
Voters: 14. You may not vote on this poll
Either boooosted, or BUILT...which one?
Old Oct 29, 2003 | 06:36 PM
Camaro00_ss's Avatar
I can't decide which to do, go boosted or go BIG!! I have the option here of getting a supercharger or heads/cam/pulleys/intake manifold with my 2000SS six-speed But which to do? Need your help in deciding for me
Old Oct 29, 2003 | 08:27 PM
95GRNZ's Avatar
Cool
Not that I wouldn't like the boost from S/C, but I like old school = naturally aspirated.
TS
Old Oct 29, 2003 | 08:30 PM
S. Holley's Avatar
S/C it you can take it off and sell it and your car is still stock.....
OH good point, HUH?!!?!?
Sell your car as stock... make half the dough back on the S/C when you sell it to me!
Old Oct 29, 2003 | 09:24 PM
Capn Pete's Avatar
BUILT.
It's just way more "personalized" and shows more thought and originality (even though everyone goes for the TR224/224 cam!!!............j/k!). IMO, there are a lot more options when it comes to building an engine:
  • different head combos: P&P stock, LS6, aftermarket
  • lots of different cam choices
  • stroker kits to increase cubes: "there's no replacement for displacement"
I know that superchargers ain't cheap either, and serious thought has to go into bolting one on an engine and making it work safely and properly, but otherwise, I consider it more like nitrous...........a "once and for all solution to stop getting beat by all your buddies!!"
Well, that's my $.02.
Old Oct 29, 2003 | 10:22 PM
All good reasons for building an engine...or going with the S/C...or...wait...
Old Oct 29, 2003 | 10:59 PM
krillanaross's Avatar
If your car is stock you will probably want to build the engine before a s/c anyway...jmo
Old Oct 29, 2003 | 11:19 PM
tailwindxr7's Avatar
Where's the option for both?
If you're going to run a supercharger you're going to want a lot of stronger forged internals to compliment it, along with lower compression, and a cam that'll work well with it. Bolting one to a stock engine will work, but not nearly as well as it could.
I like N/A, but you can make just as much power in a more streetable application with a built motor on mild boost as opposed to a built motor that needs to run a radical cam.
Old Oct 30, 2003 | 12:34 AM
I tend to agree with those who favor N/A as well. Making a strong engine stronger will set it up better for power adders at a later date..BUT..I am 3 years into a six-year warranty, and I'm afraid that altering some of the components, no matter how good the install, will void that warranty.
Opinions?
Old Oct 30, 2003 | 06:33 AM
S. Holley's Avatar
Well. If you are not looking for bang for your buck SPEND 5K on a NICE NA rebuild and then super charge it.... and make sure you get good suspension stuff....OH don't forget a NEW rear (12 bolt or 9 in) Well you might need a cage to make it LEgal on the track... Dam why not squeeze a 75-100 shot of NOS to cool the intake charge.... Well some new rims and tires would be nice to MAKE this BEAST HOOK......etc etc etc....
See my point.
N/A is a great option but hard to change...plus going with a different cam means computer tuning....possible gas and drivability problems without tuning.
YOU could always just run a LS-6 intake and stage 2 heads with headers....that would be a easy swap same you about a 1000.00 and not worry about tuning and drivability.... I knoww a guy with a 99 SS M6 setup this way running SLP heads/headers/intake...makes 360 to the wheels that is about 450-475 flywheel enough that you could take a ZO6 and run mid 12 with out any other mods... stock drivability.....
But like a said before it is hard to remove that stuff if you sell....you are selling a MODDED car with a possible abusive history....to the average guy.
Old Oct 30, 2003 | 07:53 AM
NEWBIE T/A's Avatar
Thumbs up I voted built.
Cheaper, if you compare heads & cam (installed) vs. a supercharger.
Potentially more reliable - no way to be tempted to "tweak the boost just a bit" for a few more HP's only to hear a kaboom !
FWIW, I'm not a nitrous fan, either.
I'm skeered !!
Britt
Old Oct 30, 2003 | 09:24 AM
Capn Pete's Avatar
Originally posted by S. Holley
I know a guy with a 99 SS M6 setup this way running SLP heads/headers/intake...makes 360 to the wheels that is about 450-475 flywheel
How do you figure that 360 RWHP is 450 - 475 flywheel??? That's like 20 - 25% drivetrain loss?! If this is in an M6 car, I don't think it would be that high. Maybe somewhere between 400 - 420 flywheel HP, based on a 10 - 15% drivetrain loss through the M6.
Old Oct 30, 2003 | 02:52 PM
Black01_Z's Avatar
My once and for all solution to losing to my friends was buying a Z28, It made me untouchable. Now with nitorous I am even more untouchable, well once my car gets out of the garage in the spring.
Old Oct 30, 2003 | 03:12 PM
Ken S's Avatar
In that case, adding in forced induction or heads and cam will definantly void all of your power and drivetrain warantee.. You might as well see if you can end your warantee and get a prorated refund..
Anyways, my choice would be a healthy heads/cam setup picked and installed by a experienced shop.
Opinions?
Sk8phreak88
Parts Wanted
Oct 6, 2009 11:05 PM
Roadie
Jan 25, 2006 01:44 PM
Roadie
Jan 22, 2006 08:40 PM
