EGR and Air Pump delete...
Old Mar 21, 2005 | 10:48 PM
LPE_wannabe's Avatar
Question EGR and Air Pump delete...
what all has to be done to take off the EGR and the air pump? also what problems, if any, could arise because of this? thanks a lot!
Old Mar 21, 2005 | 10:54 PM
BirchMan98z's Avatar
Re: EGR and Air Pump delete...
Undo some bolts, take out the EGR& air pumps, plug the manifolds with the blockoff plates. Tune isn't necessary but you will trip a SES light.
Old Mar 21, 2005 | 10:58 PM
so how do you get the SES light to go off...tune?
Old Mar 22, 2005 | 07:03 AM
teke184's Avatar
yes...you need to progam the AIR and EGR out of the computer. unless you have the 01/02 car which didn't have the EGR.
removing the AIR will cause your cats to fail quicker i've heard. not sure.
there really isn't any hp to be gained from removing the AIR. it only operates for 2-3 mins after startup, and is an electric pump. basically it just cleans up the engine bay.
the EGR tube inside the manifold could introduce some resistence to flow...but not much.
Old Mar 23, 2005 | 04:39 PM
so do i just fab up some block off plates for the headers and intake for the air pump? i don't have cats so there's no problem with them going out. thanks
HectorM52
Jul 30, 2017 11:46 AM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
