Dyno: What gear?
Old Jan 2, 2004 | 11:28 PM
95TA8280's Avatar
Dyno: What gear?
OK a different thread got turned around to another topic and I had to ask.
I had **** poor #s in my 01 (274/298) and I was wondering what gear did you M6 guys dyno? I did 3rd, because that was what I did in my LT1....what gear should I have dynoed, and how much did it matter?
Old Jan 2, 2004 | 11:43 PM
Eric L's Avatar
all the m6 cars should be dyno'd at 4th gear... its a 1.00 ratio
Old Jan 3, 2004 | 01:24 AM
V6toZ28's Avatar
It probably helped ...
Old Jan 3, 2004 | 11:08 AM
03EBZ06's Avatar
Yup, 4th gear is correct.
Old Jan 3, 2004 | 12:01 PM
psychocabbage's Avatar
4th gear.. its the gear I have done over 40 pulls on this car in...
Old Jan 6, 2004 | 04:21 AM
neat's Avatar
I actualy have tested this rumor on a dynojet before. I've had my car pulled in 2nd, third, and 4th gear. The numbers are all within about 10 HP of one another, with 4th yielding the highest numbers. If you want some killer numbers, have the guy run it up in third, and bang 4th while testing HP.
Old Jan 6, 2004 | 07:59 AM
chpmnsws6's Avatar
4th gear. also bump up tire pressure as much as possible and take out your air filter
that will yield a few more ponies your way
Old Jan 6, 2004 | 09:29 AM
iateyour5.0's Avatar
3rd gear should actually yield higher numbers from what I understand. I had mine dynoed at 302/315 in fourth and 278/??? in fifth.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
