dyno run
Old Mar 17, 2004 | 01:51 PM
chevy qc's Avatar
dyno run
just ran our sales managers car on the chassis dyno, here are some results.
02' Camaro SS M6
mods include: SLP Longtubes, SLP cats, SLP lid, K&N drop in filter, SLP 160 thermostat, SLP 85mm mass air flow sensor, SLP intake bellows, Corsa cat back, and Ed Wright programming.
air fuel ratio was 12.1:1 to 12.3:1 on an LM1 wideband.
rpm hp tq
2500 148.1 311.1
3000 185.3 324.5
3500 217.6 326.6
4000 256.9 337.3
4500 289.9 338.4
5000 315.4 331.3
5300 322.9 320.0
5500 321.7 307.2
6000 314.0 274.9
6500 284.9 230.2
rev limter set at 6500. hoping to pick up some after sending the computer back out to lean it up some and program the rear cats out. (damn ses light doesn't like them).
here's a pic.
Old Mar 17, 2004 | 02:04 PM
psychocabbage's Avatar
hmmm.. wasnt a particularly strong car huh?..
I was expecting more out of those mods...
hmmm... think the tuning alone should help tons..
Old Mar 17, 2004 | 02:14 PM
DanBUCF's Avatar
Did his dyno sheet look anything like this? I put down almost identical #'s without the Long Tubes...also, my air/fuel is a little more jacked up than that. Im richer.
Here's my sheet.
http://www.pbase.com/image/27002482
Old Mar 17, 2004 | 02:15 PM
PhantomTA's Avatar
Moderator
You dont need to rev to 6500 btw.. In fact I wouldnt. Nothing like valve float
Old Mar 17, 2004 | 02:24 PM
chevy qc's Avatar
it certainly didn't put out what i was hoping which is usual. i also left out the car has a 4.10 gear. temp was 63.4 in the dyno room and barometric pressure was 29.41. after the pcm is redone we might go at it again hoping for at least 330.
Old Mar 17, 2004 | 02:47 PM
chevy qc's Avatar
Here's my sheet.
impressively similar, yes. as for the run to 6500, that was just in amusement to see how bad it fell off that high up. the rev limiter was moved up that high because the guy driving it kept hitting the stock one on a regular basis as well as hitting it every time a burnout in in process. now it has a bit more time to grab the next gear when burning them. when running it hard, it's shifted around 5800 to 6000.
Old Mar 17, 2004 | 08:08 PM
what was his rwhp before the mods?
I am thinking that the 85mm slp maf may be hurting him.. maybe the tuning is hurting him.. not sure what it is but either that car didnt have much to start with or something isnt right there...
catback and lid should put down those numbers..
Old Mar 17, 2004 | 09:41 PM
chevy qc's Avatar
never did get it dyno'd stock. i'm going to look into the power issue because i was hoping for 350 and it's off. the pcm is going back to ed wright to fix the rich condition. it's even turned the pipes black it's rich enough. the maf wasn't my choice, but i was hoping the programming would fix that. he also drove in off the highway and pretty much just had it strapped down, no cool off. before summer i hope to have it strapped back down for 340+ and some track times.
Old Mar 18, 2004 | 12:51 PM
262guy?'s Avatar
Wow that is a nice lookin guy in that pic (me)...eeerrr...uuummm. I mean nice lookin SS. You know what I mean. I was hoping for some more too. I had my bet on 362 with the mods. I don't think the 85mm MAF is helping either. The stock ones work good on the bolt on cars from what I have seen. I also know that car was hot when it went onto the rolllers. I herd the e-fans kick on just as he was backing it onto the hoist (BAD). Too hot, and tunning needs to be done. Do you think he will let you hit the track with it Mike. We could take turns driving it !
Old Mar 18, 2004 | 01:18 PM
boomcase's Avatar
I have never been a fan of mail order tunes, Ill bet you can get alot more out of that car with a good LS1 edit tune or hp tuners program, BTW 12.1 is alittle rich on the airfuel nothing like being able to up the timing and fuel to see what it does on the dyno.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
alex5366
Feb 17, 2015 09:07 AM
Jlo
Feb 3, 2015 09:41 PM
chevysam
Jan 16, 2015 07:45 PM
birdblack
Dec 30, 2014 06:59 PM
