does your stock Y-pipe hang really low?
Old Oct 22, 2003 | 09:14 PM
Amit's Avatar
the fricken thing scrapes soo much.. i harsh have to drive carefully over bumps and sh¡t.
i put it up on a hoist and i couldnt even move the thing.. its not loose or anything, it just hangs really low.
is there a fix for this?
oh yeah my car also came with the bilstein ultra high performance suspension package from SLP.
i believe this setup lowers the car rougly an inch, but still...
any help would be appreicated
Old Oct 22, 2003 | 09:29 PM
Aklaim's Avatar
Yes, they all hang low.
Old Oct 22, 2003 | 09:34 PM
JaysGone's Avatar
Im lowered an inch and change. The only thing that scrapes on my car is the tunnel brace. Easy way to adjust Y pipe is loosen up everything from the collectors to the I-pipe. Wedge a 2x4 under the tunnel brace pull down on it . Then retighten everything
Old Oct 23, 2003 | 07:15 AM
teke184's Avatar
JaysGone
holy five line maximum on sig lenght!!!
as for the ypipe...yeah they thend to be low, you should see how much lower my bassani offroad pipe is...gonna be tough when i lower the car this winter.
Old Oct 23, 2003 | 08:08 AM
Ron78Z&01SS's Avatar
Yeah, mine hangs REALLY low on the driver's side. You can see the flattened pipe hanging as you walk towards the car.....it looks like cr@p . Almost looks like some work was done on the exhaust and the Y didn't get reinstalled evenly. I'll take care of it next time I have it on a lift.
Old Oct 23, 2003 | 11:29 AM
Amit's Avatar
this works? really?
im gonna try this
Old Oct 23, 2003 | 11:43 AM
Ed's 01 SS's Avatar
Low stock Y-pipe
I tried to get the dealer to reposition the unsightly y-pipe shortly after I bought the car (2001) but they said it complied with the GM spec and didn't need to be raised. It appears all new Z's and SS's are like this.
So, I did it myself by loosening all of the connections to the pipe, jacking the left side up about 3/4 inch then re-tightened everything. It looks good now with no leaks, no problems and no banging, although I do have an A4.
Old Oct 23, 2003 | 12:18 PM
therealmagyver's Avatar
It's hanging low for a reason. Look at it when someone else starts your engine...the suckers moves up. Thats why a lot of people complain about y pipes banging on the driver side. There are workarounds and some lift up less then others.
Old Oct 23, 2003 | 04:56 PM
JaysGone's Avatar
Thers alot more thats all I could squeeze in. As for the "stock"Y-Pipe banging??? You guys must have some serious potholes in your towns. Any aftermarket pipes going to be even lower on the left side then the flat stock pipe is now. I wouldnt lose any sleep over the occasional scrape it wont hurt anything
Old Oct 23, 2003 | 05:23 PM
I wouldn't worry either. I drove thru a flood and tried to be slick and cut onto the sidewalk....what a mistake. I was grinding and scraping all over the place. The dirt on the sides of the side walk sunk and the were the round bricks/rocks place in the dirt too!!! I was hating life when I drove throught it for about 5 car lenghts. The car is fine underneath.
Old Oct 23, 2003 | 05:31 PM
Slappy3243's Avatar
Mine hangs pretty low as well. You can see it when approaching the car. I was told it was normal so I don't let it bother me.
Old Oct 24, 2003 | 12:02 AM
psychocabbage's Avatar
I think he meant that you shouldnt have so much in there as a mod will have you remove some of the lines.. I used to have an 8 liner myself..
Old Oct 24, 2003 | 01:47 AM
JaysGone's Avatar
SHHHHHHHHHHHHHHHHHHhhhhhhhhh
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
