Do verts come with SFC's already built in?
Old May 20, 2003 | 08:29 PM
gearslammer's Avatar
This is what a buddy of mine told me. Mainly because there is no body stability. If they are standard then what besides an upper strut tower brace can I put in to help fortify the handling?
Old May 20, 2003 | 09:31 PM
2002Z28SSConv's Avatar
They already have some extra braces and supports. They're not really sub frame connectors. But they do stiffen the car somewhat.
Old May 20, 2003 | 09:38 PM
sleeperZragtop's Avatar
There is an x-brace under the tunnel....the k-member has bolted in rods to help stiffen up the front....and the frame rails run from the behind the front wheel to the front of the back wheels...check out a t-top and a vert frame...way different....but it is always good to add in SFC's
Old May 20, 2003 | 10:06 PM
So there is still some SFC's that aren't stock? What about strut tower braces? I am told they make a world of difference.
Old May 20, 2003 | 10:13 PM
Check out www.bmrfabrication.com and check out some good value for your dollar SFC's or you can spend a litttle extra money and get KBDD's...they are 3 point...as for STB...there nice as well. BMR makes em as well...cheap
Old May 21, 2003 | 06:10 AM
mcflyz28's Avatar
Put on some BMR's you'll be amazed at the difference. I was
Old May 21, 2003 | 08:12 PM
thanks guy's
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
Jake Bialke
Sep 24, 2015 11:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
