Do LS1's Have Forged Internals?
Old Nov 4, 2002 | 09:15 PM
DJ:BOTA's Avatar
From: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
Pistons, etc? Just wondering.
Old Nov 4, 2002 | 09:30 PM
chuck's Avatar
The pistons are Hypereutectic (high silicon cast), the rods are powdered metal and the crank is cast. If it were forged I would shift at 7K instead of 6500. The crank seems very tough, but the pistons and rods can fail when pushed too hard.
Old Nov 4, 2002 | 10:38 PM
DJ:BOTA's Avatar
Can they handle more boost stock with a S/C, or are they the same as the LT1?
Old Nov 4, 2002 | 10:41 PM
Big Red Jim's Avatar
LS1s weren't built to handle boost very well from the factory. You could probably get away with 6 pounds of non intercooled boost, or 8-10 pounds of intercooled boost for a while. Eventually you will probably pull a ringland apart.
Old Nov 4, 2002 | 11:15 PM
DJ:BOTA's Avatar
TY for the help.
Old Nov 5, 2002 | 08:28 AM
PhantomTA's Avatar
Moderator
the only thing half way decent inside the ls1 is the crank its not forged but its a pretty strong cast steel crank! The rods on the other hand arent great (im running arp rod bolts to help them hold together an extra 100 or so rpm. And well factory hytperjunk pistons are fine on motor, but suck with a power adder!
Jocofire1
Aug 7, 2015 03:16 PM
alphaauto
Jul 26, 2015 04:40 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
