Do I really need to spend $150 on an oil pump?
Old Jan 25, 2004 | 10:16 PM
Mike94ZLT1's Avatar
Do I really need a ported, polished, balanced, blueprinted blah blah blah oil pump you find everywhere for around $150? Would I be just as well off switching to an LS6 oil pump you can get for 60 bucks from GM parts Direct?
Old Jan 25, 2004 | 10:37 PM
Ferocity02's Avatar
Get a ported LS6 pump from TSP, they are about $120, no problems with mine.
Old Jan 26, 2004 | 02:52 AM
jrp's Avatar
jrp
:werd:
Old Jan 26, 2004 | 10:59 AM
SSCamaro99_3's Avatar
I would, just because $150 is a whole lot less than a motor rebuild. If you're in there, put in new parts.
Old Jan 26, 2004 | 11:28 AM
Mike94ZLT1's Avatar
Oh I fully intend on using new parts, its just that I can get a brand new stock LS6 oil pump for around 60 bucks from GM parts direct. Is it really worth the extra 90 bucks for a ported one?
Old Jan 26, 2004 | 01:59 PM
Most likely not. The LS6 pump should be fine. I got my Katech pump for about $119.
Old Jan 26, 2004 | 04:40 PM
mcflyz28's Avatar
My answer if the stock one is working fine leave it alone
Old Jan 26, 2004 | 06:26 PM
chpmnsws6's Avatar
just get the ls6 one... non ported.
maybe you can even port em urself....
Old Jan 26, 2004 | 11:51 PM
99huggerorangeZ's Avatar
go to SLPs(slponline.com)you can get a ls6 oil pump/timing chain combo for 250 or something like that
Old Jan 27, 2004 | 03:20 AM
Gold Z's Avatar
The ported pump is overkill. The stock pumps supply plenty of pressure and volume for any streetable engine. They are like gold plated valve covers....they are nice to have but hardly a necessity.
Old Jan 28, 2004 | 08:54 PM
jrp's Avatar
jrp
or you could go to TSP (texas speed) and get a ported ls6 pump and rollmaster double timing chain for 205.
Old Jan 28, 2004 | 09:02 PM
AL SS590 M6's Avatar
Moderator
I had understood that the main purpose of the work done on an LS1/6 pump was the honing and polishing of the pressure relief valve bore. To keep it from sticking open and trashing your engine as many have done.
I bought one from Thunder Racing for my build up.
Old Jan 28, 2004 | 11:06 PM
Mike94ZLT1's Avatar
Yeah, but wasnt that problem was a lot more common in 98 and earlier 99 model cars? What about an LS6 pump? That engine didnt even make its debut until late 2000, long after the last of the "bad" pumps had left the line. How many people who own LS6 powered cars have had this problem?
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
