Do I have an oil leak or what?
Old Dec 31, 2003 | 10:06 AM
Buffdaddy's Avatar
At about 2500 miles from my last oil change I had to use a quart of oil(mobil 1). I think I have to put in another quart because the low oil light just came on. It has only been about 6 weeks, I have not checked my parking spot yet but is it just a leak or something maybe worse. thanks.
Old Dec 31, 2003 | 01:12 PM
camaro322hp's Avatar
is there a puddle of oil under your car? the more likely answer is you're burning oil. it's not uncommon for my car to use one quart per 3,000 miles. there are quite a few guys on the board with oil usage.
i really don't sweat it, since one quart low is at the bottom of the "ok" area on the dipstick, and i change my oil religiously at 3k miles. if you're really worried about it, there are a few fixes out there with mixed results, which include switching to a higher viscosity oil, or a mix of oils, and catch can/fuel filters installed in the PCV line. i'm sure others will elaborate on these fixes. i can't since i haven't tried them...
Old Dec 31, 2003 | 02:07 PM
ExMustangOwner's Avatar
Don't sweat it. It's normal for LS1's to burn oil (some more than others) I have to add a quart once before every 3000 mile oil change. That low oil light lets me know like clockwork when I have 500 miles before and oil change. It's kinda funny.
Old Jan 2, 2004 | 12:36 PM
HellSpawn T/A's Avatar
Dont worry about it, most F bodys burn oil, some of them leak, but its not enough to worry about, mine leaks, but its only like maybe a 1/4 of a quart every 3000 miles. You'll be fine
Old Jan 2, 2004 | 05:18 PM
Greed4Speed's Avatar
Only leak I had was from the gasket on the drain bolt getting hard and cracking.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
