Disapointed With Track Times
Old Jun 10, 2005 | 11:08 PM
02BlackSS's Avatar
Well I just got back from the New England Dragway in Epping New Hampshire and I am not happy with my times. I have a 2002 SS M6, All I did to it was 1.75 drop and flowmaster muffler not cat-back just the muffler. I ran a 14.0 @ 102. I am thinking I should trapping higher and running more towards a 13.5. What do you guys think..
Old Jun 10, 2005 | 11:18 PM
redfbird's Avatar
Re: Disapointed With Track Times
yeah, you should be around 13.1 at 106 in your my car is bone stck
Old Jun 11, 2005 | 12:10 AM
whitehooptie's Avatar
What are your short times?
Old Jun 11, 2005 | 07:05 AM
psychocabbage's Avatar
ya.. my car is factory bone stock and trapping 108 (13.1's)..
How are you shifting?
Please describe in detail your process of staging and then heading down the track..
Old Jun 11, 2005 | 09:43 AM
02BlackSS's Avatar
Well, I can't tell you my short times because they were not handing out slips because the machine was not working, What I can tell you is I spun through 1st and 2nd, so my 60' and 1/8 mile probably suck, I did have 3/4 of a tank of gas and I just checked this morning and my tires had about 38lbs in them. I am shifting just at redline through each gear and I'm shifting hard. It was very humid and sticky last night so I don't know if that had anything to do with it.
Old Jun 11, 2005 | 09:47 AM
00ls1's Avatar
sounds like traction problems im sure your 60ft times were very high
Old Jun 11, 2005 | 09:48 AM
shadydavy 95 TA's Avatar
The track was way off if you spun through first and second, and hot and humid weather won't yield good results either. With a stickier track, maybe stickier tires, more practice driving your LS1 down the track, and cooler air low to mid 13s should be in sight.
Old Jun 11, 2005 | 10:27 AM
02BlackSS's Avatar
cool, thanks guys.
Old Jun 11, 2005 | 02:49 PM
CrabhartZ28's Avatar
Did you warm up the tires at all? Even street tires should grip pretty well if you stage them right.
Old Jun 11, 2005 | 05:07 PM
02BlackSS's Avatar
yeah I warmed them up...
Old Jun 11, 2005 | 07:16 PM
Camaro Rick's Avatar
hey 02BlackSS,
it's too bad, i was going to go to epping last night...but instead i was in connecticut where i bought my first ls1 f-body. it's a 2000 black SS M6. where in mass are you? i'm about 25 minutes away from epping in manchester...
Rick M.
Old Jun 11, 2005 | 08:27 PM
Green G0blin's Avatar
i hit a 13.4@104 stock 1.9 60 ft
Old Jun 12, 2005 | 09:36 AM
02BlackSS's Avatar
hey camaro rick, I live in Marlboro about 50 minutes from Epping. You didn't miss much we all got rained out.....
Old Jun 12, 2005 | 11:50 AM
UtOhCop's Avatar
You need some practice drag racing and the times will come down.
Old Jun 12, 2005 | 12:42 PM
danno02SS's Avatar
In drag racing, it's all about traction. My 1st few bone stock runs yielded dissappointing 14.0x@101-102 on 2.3x 60's. By the 5th run, I had gotten the ETs down to 13.832@102.5 on 2.2x 60's. Pratice and patience (which I didn't have) should get you to mid-13s if not better in your current state with a 2.0 or better 60'.
Also, lowering your car hurts your 60' (more wheel hop). It throws off the rear-axle geometry. Look into getting some LCA relocation brackets.
