Dim spot on speedometer?
Old May 2, 2003 | 06:48 AM
Lilbear's Avatar
Okay, I know I'm being petty about this but could somebody tell me if on their speedo at around 150 mph if it's dim like there's no bulb under that section. Mine is dim. Not so dark you can't see the numbers, but dim. My car is still under warranty and if that's suppose to be lit, I want it lit.
Old May 2, 2003 | 07:27 AM
Darth Xed's Avatar
Ya, I noticed the same thing on my 99...
I think that's just the way it is.
I always thought I had a bad bulb there or something, but now that you say you have it too, I'd imagine that is the way it is... though I guess we both could have bad bulbs.
Old May 3, 2003 | 06:34 PM
OutlawLS!'s Avatar
Mine has the same problem, its not really that dark but its a little dim. It kinda bothers me, but I figure its not really a huge deal. I will look more into it when I get guages.
Old May 4, 2003 | 02:18 AM
fbird95's Avatar
thats how it goes. there is a little dim spot there on my car as well. Another question would be why do the pointers on the gauges light up at different intensitys? Especially the larger pointers (speedo and tach) the little arrows are nice and bright.
Old May 4, 2003 | 02:21 AM
camaro6's Avatar
When i had my 92 camaro, part of the spedo was dim so i took it in and found out that a bulb was burnt out so it was changed. It could be a bulb
Old May 4, 2003 | 02:26 AM
Ferocity02's Avatar
I have the same problem but on my tachometer. From 0-1000 the tick marks are dimmer than the rest of them. I really don't mind becuase I can still see them and I have no plans to get it repaired.
Old May 4, 2003 | 01:58 PM
fbird95's Avatar
Its more or less GMs light paths behind the gauge panel, their not as good as they could be, and equal light doesnt reach all the points. I have seen many delco radios and Heating/cooling controls that have had this same issue. Just one more GM (General Mistake) to deal with. Besides I would rather have a dim spot in my instrument panels than drive a ford.
Old May 4, 2003 | 04:00 PM
Schismblade's Avatar
Same here. The 150-155 on mine is also a tad dim.
Old May 4, 2003 | 05:46 PM
WhoBetter?'s Avatar
I've got it too.
fift5
11
Oct 1, 2015 10:31 AM
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
ChrisFrez
Sep 9, 2015 06:52 AM
