Difficult to bleed coolant system?
Old Nov 8, 2004 | 04:43 PM
RobertoZ28's Avatar
All I'm gonna do is pull the thermo not even disconnect the hose, and put it back on. Think that air I get in the system will be hard to bleed off??
Old Nov 8, 2004 | 10:44 PM
mebanditws6's Avatar
Re: Difficult to bleed coolant system?
Yes You have to pull the hose off to get the thermostat out. Anytime you open the cooling system like this you need to bleed the system.
Jason
Old Nov 9, 2004 | 04:40 AM
AL SS590 M6's Avatar
Moderator
Bleeding an LS1 f-body is really easy. Unhook the TB coolant line and fill the radiator up. When coolant comes out of the unhooked line or where it was hooked you're done.
Old Nov 13, 2004 | 01:52 PM
Grave's Avatar
Where's the TB line??
Old Nov 13, 2004 | 01:58 PM
RobertoZ28's Avatar
he is talking about the Throttle Body line. Yeah, makes sense, being that is the highest spot in the system. You have to go slowly tho.
Rod Bender
Nov 7, 2023 02:30 PM
blac94Z
Feb 15, 2021 09:43 PM
warmeck
May 31, 2015 11:29 AM
Biggiebound
Apr 21, 2015 11:28 PM
Sandersen511
Jan 13, 2015 03:49 PM
