Did my Rotors Warp?
Old Sep 18, 2003 | 11:01 PM
BigRedZ28's Avatar
Did my Rotors Warp?
Okay, heres the story.. I was Racing a Trans Am, and I hit about 90.. the road is kinda closed off into a narrow pass over a bridge and I was slowing down, all of a sudden my back end gets kinda loose... **** they'res a bunch of Rocks and Dust on the left lane from the construction, so I pushed alittle harder now after letting off quickly because I wasn't going to be able to slow down fast enough for the narrow pass into the bridge! So my Car decides to Go left then slam itself right into a 360 spin at say 40-50mph!!! and then I stop about half a foot from the curb.. cause of those damn pebbles... New Breaks are in the "Mod List". But Do you think I warped them? I just read about a guy warping his Breaks instantly from high speed breaking on the High Way but he was going ~140mph... I only noticed alittle tighter Grip on the breaks, and some Squeeking, but Hawk Pads are suppose to be alittle noisy..
Old Sep 18, 2003 | 11:31 PM
chasmanz28's Avatar
Re: Did my Rotors Warp?
you should be fine, if you dont feel vibration when you apply the brakes your fine, now if you ran over water with the rotors being hot then you might have a problem
Old Sep 19, 2003 | 12:55 AM
zoomjrl's Avatar
sounds scary, do you have ASR? Glad to hear u missed that curb, I wasn't so lucky.
Old Sep 19, 2003 | 12:57 AM
99blackSS's Avatar
I don't think your brakes are warped. My brother managed to warp the rotors in the V6 camaro, normally applying the brakes on it felt like the brakes were being tapped every other second, it was quite annoying to drive.
I raced a Trans Am and was doing 120mph(this was at a track of course) when I had to stop all of sudden for a traffic light. (Yes, that's right, there was a traffic light in the middle of the track). I could smell my brakes but my rotors are fine.
BTW, made three runs and won three
Old Sep 19, 2003 | 03:19 PM
Ken S's Avatar
probably fine..
sounds like while you were intially braking hard with all your weight being trasfered forward, something upset the rear.. be it the road or driver.. then you made matters worse by giving jerky inputs that further upset the car (plus the road conditions) causing it to go into a 360..
if you're going to race on the streets, at least don't do it near construction...
93 RedBird
Nov 15, 2015 08:24 AM
HibachiZ28
Nov 6, 2015 12:53 AM
jayblev95
Sep 26, 2015 09:44 PM
Henson071
Sep 18, 2015 04:01 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
