Did Comp Cams update the 918 Springs??
Old Jan 13, 2008 | 08:03 PM
Bayer-Z28's Avatar
I thought I remember hearing something about this somewhere. It'd be about time for Comp Cams to do something w/ their single coil Beehive design valve springs..
I can't find anything on the CC websitge, but I thought I saw an article in GMHTP about it..
Old Jan 13, 2008 | 10:25 PM
Kraest's Avatar
Retired
I believe they are called something else now... Comp 12xx ?? .... not really sure. I only use the Patriot Golds and PRC Duals, which are basically the same thing
Mike
Old Jan 14, 2008 | 02:37 PM
Matt@Texas-Speed's Avatar
They did change the design and all on the 26918. Here's some new info on them:
• Extended .625” max lift, 125 lbs seat pressure at 1.800” installed height for aggressive cam designs
• Incorporates 10+ years of Beehive™ Valve Spring development and refined manufacturing processes
• Designed with GM Gen III/LS engines in mind – for use with hydraulic and solid roller camshafts
• Features manufacturing processes found in exotic race springs, providing a unique silver satin finish
Seat Load: 125 lbs @ 1.800" Open Load: 367 lbs @ 1.100" Coil Bind:1.100"
We try to keep these as well as the PRC dual spring kits in stock at competitive prices! Give us a call or shoot me a PM if I can help!
Old Jan 14, 2008 | 04:03 PM
Bayer-Z28's Avatar
^ I'll be getting a set of PRC Duals off you guys soon.. I'm piecing together a cam build..
Thanx Boss!
Old Jan 14, 2008 | 05:24 PM
Greed4Speed's Avatar
Is this recent? IIRC the changed things up way back when they had breakage issues and came out with the blue stripe 918's.
Old Jan 15, 2008 | 06:52 PM
Bayer-Z28's Avatar
^ I thought the update was somewhat recent since I've never heard any news about an update to the 918 design..
Old Jan 15, 2008 | 07:51 PM
angel71rs's Avatar
They had issues again recently:
http://web.camaross.com/forums/showthread.php?t=526319
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
