Denso O2's, please help
Old May 4, 2008 | 03:22 PM
scof0elife's Avatar
Okay guys, I have longtube headers and I'm convinced that my o2's are the reason why I am getting bad gas mileage. I plan on getting Denso O2's from sparkplugs.com. Now which one's do I order, such as OE Identical vs Universal and which Front and Right O2's do I get because there are 2 different kinds. Also, will the o2 extensions I have on my car now connect okay with the Denso's? I also forget, I would be getting front o2's to connect the extensions with for my longtubes correct?
If someone can help me out asap, I would like to order these today or by tomorrow morning so I can have them by the end of the week. Thanks!
Old May 5, 2008 | 06:24 AM
AL SS590 M6's Avatar
Moderator
General consensus is just get Delcos. Bank 1 and 2 pre cat (sensor 1).
If you go aftermarket get OEM replacement style then your extensions will work.
Old May 5, 2008 | 11:02 AM
scof0elife's Avatar
Thanks, do you know any good place online to get o2's for a great price? Do you think it's safe for me to by used stock o2's from someone on here or ls1tech?
Old May 5, 2008 | 11:17 AM
Chrome383Z's Avatar
You could probably get away with it, but I personally wouldn't run used 02s unless they were NIB.
Old May 5, 2008 | 11:34 AM
scof0elife's Avatar
your probably right, also with new NIB o2's would for sure show it o2's were the one causing me bad gas mileage.
Old May 6, 2008 | 12:33 PM
Sparkz28ss's Avatar
I love the Denso's...and I will most likely never run bosch or Delco again..great 02 if you are using a power adder
the universals are fine ...thats what I use in my LT/LS engines
Old May 6, 2008 | 12:44 PM
scof0elife's Avatar
HarrisSpeedWorks
N2O Tech
37
Sep 24, 2017 02:58 PM
