damn camaro
damn camaro
pull it in the garage, change the oil, start it up, pull off the ramps, clean garage, get in to leave, turn key, nothing. not cranking or anything, fuses are fine but the security light blinks when you turn the key to start and to ACC. tryed my extra key and got the same result. any ideas guys? kevin
Re: damn camaro
You need to have it towed in to the dealer and have the ignition looked at. Im sure your going to have to get a new ignition installed. Mine did the same thing and I had to have the dealer install one for me.
Re: damn camaro
Originally Posted by anasazi
the ignition in the column is prolly busted
i've seen people put some sandpaper onto a toothpick or something and shove it in there to clean off the contacts, might try that.
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
