Cut out or No Cut Out that is the question!
Old Feb 24, 2003 | 05:30 PM
  #16
WhoBetter?'s Avatar
you going to spend about $150 for the parts for an electric cutout and then atleast $40 to weld in it and then all the pain in the *** crap wiring it. I would reccomend just spending the extra $100 and getting a real exhaust system that sounds good and looks good and that's eay to install. The cutout sounds great at WOT,, it scares the chit out of people,and it sounds good below 2000 but in between it sounds kind of annoying just by being too loud and vibrating the car. with the cut out you won't feel a difference but with a system you will. the flowmaster does add 20hp, it's design creates a negitive back pressure that pulls the gas out.
Old Feb 24, 2003 | 05:52 PM
  #17
Black01_Z's Avatar
Im sorry did I read your sig wrong cause it says you have an F-body. Are you sure its not a Honda.
BTW the spoiler creates aerodynamic pressure adding at least a 100 HP.
Old Feb 25, 2003 | 12:01 PM
  #18
2002 NBM Bird's Avatar
Yes
www.quicktimeperformance.com
They have a very nice cutout
Old Feb 25, 2003 | 12:05 PM
  #19
Are you serious??? Guy above me talked about the flowmaster system.....But did you really have a hard time installing the wiring for an electric cutout??? If thats hard, do you struggle changing the time on your clocks when it is daylight savings time???
Doing the wiring for an electric cutout is a breeze
Old Feb 25, 2003 | 12:54 PM
  #20
stik6shift98's Avatar
electronic cutout is easy to install
Old Feb 25, 2003 | 01:13 PM
  #21
civic_hunter's Avatar
there should be a gain w/cut-out on aftermarket exaust system
you won't gain any horsepower with the cutout open on an aftermarket exhaust over the stock exhaust. That's the point of the cutout, to bypass the exhaust. I gained 9 rwhp and 8rwtq with the cutout open vs. an aftermarket exhaust. The dyno numbers in my sig are from a K&N filter and the cutout. No other performance mods.
wrong. a cut-out is like running w/o an exaust basically so even if you had a aftermarket systems there should be a small gain. If not that's like saying a aftermarket exaust flows better than no exaust at all if i get what your saying so it's after market exaust from light to light, places where you dont want the car to be to loud etc. and open cut-out for midnite digs
Old Feb 25, 2003 | 01:21 PM
  #22
JDHarris's Avatar
Okay, let me clarify... What I was saying with the cutout on the stock exhaust vs. the aftermarket exhaust is this... If you have a cutout right after your cat, have the cap off of it, and have a stock exhaust after the cutout and dyno the car, you won't see a power difference (with the cap open) vs. the car with an aftermarket exhaust with the cap open. The cutout bypasses the exhaust entirely. You WILL see a power gain with the cutout on the car and the cap open. Exhaust after the cutout makes no difference in horsepower with the cutout open, it does make a difference with the cutout closed.
Old Feb 25, 2003 | 01:44 PM
  #23
gotcha
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
