Curious what happens if you stall when in gear...
Old May 11, 2003 | 02:15 PM
1badLS1M6's Avatar
You know those times when you start thinking about something, and you can't rest until you know the answer? Well here's one of them...
Lets say, hypothetically of course, that you're driving an M6, in 6th gear, and highway speed for example. What would happen if the engine died while in gea? Would it sound like its still running since its still in gear, but just come to a stop? Would you not hear the engine at all?
Also, does stalling out damage anything? Like if you just dont give it enough gas, or forget its in gear and let the clutch out?
Just one of lifes mysteries I would like to know the answer to.
Chris
Old May 11, 2003 | 03:40 PM
fbird95's Avatar
I am not sure what exactly your asking, but here goes. If you stall somehow or the car suddenly dies on the highway, without pressing the clutch in, the car will slowly decelerate and the rpms will fall on the tach, you will still hear the car untill it gets pretty slow. This could happen if somehow a few of your spark plugs just fell out of the car. Stalling out every now and again hurts nothing, but your self esteam. now if you were on the highway and you you turned the key all the way to off. Now this would be bad. Hope that helps
Old May 11, 2003 | 06:46 PM
1badLS1M6's Avatar
You answered my question perfectly, thats exactly what i was wondering. Thanks!
Old May 11, 2003 | 07:44 PM
1999redt/a's Avatar
now if you shift from 6th to 2nd then u have problems too.,.
Old May 12, 2003 | 12:43 AM
fbird95's Avatar
I didnt see that in the post, but a 6th to 2nd shift, their would be nothing good coming out of that.
Old May 12, 2003 | 03:39 PM
Freak's Avatar
actualy that would be totaly dependant on speed. at 70 MPH you could shift into 2nd and not damage anything. it would be pointless, and you might wonder who hit the brakes, but at that speed (assuming of course stock gearing/tire size) you would only be turning about 5600 RPM in second.
Old May 12, 2003 | 07:59 PM
fbird95's Avatar
Keep slamimg the car from 6th gear to 2nd or even third, and i assure you that will certainly damage a lot. Go ahead test it out, and get ready to throw in a clutch a lot sooner and those syncros that are known for not being the strong point of the trans, they'll take one hell of a beating too.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
tommalcolm
Sep 11, 2015 03:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
