crunching from rear going over bumps
Old Aug 17, 2003 | 02:12 PM
ggsz28's Avatar
My '99 T/A has a crunching noise from both sides in the rear when going over bumps. I can even hear it slightly during slow turns in a parking lot. My '98 T/A used to do this in the cold but it's 80 degrees here. Do I need new shocks or what? The car is bone stock with 40,000 miles.
Thanks!
Old Aug 17, 2003 | 05:04 PM
steelerfan's Avatar
I had the same thing happen to my 99.It turned out to be the bushings in the LCA's believe it or not.I tried spraying them down with lube but it didn't help much.I bought a pair of Lakewood LCA's with poly bushings and grease fittings and that took care of the problem.Have someone push up & down on the car while you locate the source of the sound & see if that's where it's coming from.Good luck.Got my LCA's from Summit for around $75-80.Best price I could find
BLK1997Z28
May 2, 2015 01:26 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
Jazsun
Dec 29, 2014 12:14 PM
ModdedNerd
Dec 25, 2014 05:51 PM
