Correction: 6$Smooth Bellow
Old Dec 4, 2003 | 02:11 AM
  #16
robb4964's Avatar
Originally posted by zoomjrl
with the hump hose/SLP design, is the rib on the outside or inside too? I realize it absorbs enine movement with is important, but i'm curious if the inside is smooth or dips with hump?
Its no tthat big a curve , IM sure air it dips , but i dought it causes enough turbulance to decrease air flow badly .
Old Dec 4, 2003 | 10:02 AM
  #17
spawnz28's Avatar
That is why I decided to go with the SLP bellow. The other ones posted on here for $12 bucks or whatever that you can buy at home depot have more of ridge to them. That can cause air swirl. The SLP has less curves on the inside tubing. I posted two links below. One for the $12 "hump hose" that you can get from home depot and the $43 SLP smooth bellow. You can see the difference and see that the SLP has less curves on the inside tubing where the air would pass. Also the SLP bellow is made for cars and is designed to withstand the elements. The ones from home depot are probably not made with that in mind. My 2 cents.
http://www.proformancemotorsports.co...High-Flow.html
http://www.fbodymotorsports.com/inc/...l?v=1&pid=9455
Old Dec 8, 2003 | 07:31 PM
  #18
KamaroL98's Avatar
I tried useing a fernco as a alternative to paying $40 for an SLP bellow, but i found it didnt line up as easy or fit as well, or as easy to take on and off as the SLP bellow, especially with the way the back of the air box sits at a wierd angle with the MAF. I say SLPs is worth the $40 to me just becais of the way it fits.
Old Dec 8, 2003 | 10:30 PM
  #19
Beast96Z's Avatar
When all the pieces are combined, the SLP makes everything one smooth piece. The fernco would have a ridge at the back of the MAF and the front of the TB. That is why there is a "bubble" in the SLP. It also has the angle built in to make everything line up good. If your gunna get one, just spend the extra on the SLP.
Old Dec 15, 2003 | 11:26 AM
  #20
robb4964's Avatar
I bought one of shose hump hoses from airflow systems inc , and it does not look longh enough to fit on My car ...How long does it have to be ?
Old Dec 15, 2003 | 06:00 PM
  #21
JaysGone's Avatar
If you have an aftermarket lid it will fit. If anything you may have to trim it a bit to make the lid fit properly. Stock lid is NG from the get go no matter whos bellows you have
Old Dec 16, 2003 | 02:01 AM
  #22
MistaCamawo's Avatar
anyone have any dyno results from this? My car already came with a smooth bellow, so I wouldn't know if it was a noticeable difference.
Old Dec 16, 2003 | 07:57 PM
  #23
rncotton's Avatar
well, after testing several sizes from AirFlow Systems .... The 3.5 - 3.5 hump hose is a great fit.
The 3.5 fits over the MAF without any trouble, and the 3.5 stretches enough to fit the TB without much effort. No clamps required.
Old Dec 16, 2003 | 08:39 PM
  #24
JaysGone's Avatar
For the last time folks. This is the hose you need from airflow with a lid. http://shop.airflowonline.com/Mercha...t_Code=40R35SL
Stop using washing machine parts
Jeff1904
Jun 5, 2016 05:00 PM
Bxlt1
Sep 29, 2015 03:18 PM
mlopezart
Sep 8, 2015 12:15 PM
karpetcm
Aug 14, 2015 03:02 PM
