Coolant Level Light
Old Jun 19, 2003 | 11:41 PM
fillaZ28's Avatar
Question Coolant Level Light
Coolant level light came on. Checked coolant full in radiator and overflow jug. Will stay on some times. Other times it will go out. Where is the sensor located, how much work involved to change? Anything else should check before replace. Car runs at normal temp.
Old Jun 19, 2003 | 11:58 PM
camaro322hp's Avatar
yeah, that happened to mine. coolant level sensor was bad. had mine taken care of under warranty. i think it's fairly common for our coolant sensors to go bad...
Old Jun 20, 2003 | 12:19 AM
crushtheogre's Avatar
coolant light
Yea mine started that about 2 weeks after the warranty ran out on mine So I know what your talking about and its been driving me nuts. Does anyone know where the sensor is and where to get another one (besides a dealer)?
Old Jun 20, 2003 | 12:33 AM
SSpdDmon's Avatar
If you could call the dealer and get the part number, you might be able to pick up the part @ http://www.gmpartsdirect.com/ for about 2/3's the cost of what the parts dept. charges.
Old Jun 20, 2003 | 01:41 AM
AL SS590 M6's Avatar
Moderator
It's the square thing sticking out of the engine side of the radiator just under the upper radiator hose. Unplug the wire then pull the spring wire clip and pull it out. It will run you ~$40 and only last for a short time. Try taking it out and cleaning it off real good with alcohol. It will sometimes work for a while after doing that.
They work so good that in the later models it was deleted.
Old Jun 20, 2003 | 07:49 AM
NEWBIE T/A's Avatar
Thumbs up Shoeboxe's site will show you the way !!
Pretty common '98 & '99 problem.
As stated by AL SS590 M6 , this neat feature was eliminated in the '00 & up cars.
(Ironically, my wife's '02 L300 Saturn has one ... )
At any rate, see:
http://csce.uark.edu/~jgbertr/rb/4th_gen_tech1.html
Click on "Remove Low Coolant Sensor" & Wa Laa !!
I'll get to mine one of these days - it does not do it when the temp outside is over ~ 70. When it does do it, I run the car to 1/4 on the temp gauge, shut it off, and restart it - that kills the light.
Later !
Britt
Old Jun 20, 2003 | 11:01 AM
Constrictor98TA's Avatar
This is exactly what I had to do when this happened to mine and its been okay since. Just take it off and clean it up with some soap and water and put it back in. If that doesnt work, then replace it.
captcorvette
Mar 7, 2015 12:37 PM
BMX Dad
Jan 23, 2015 07:00 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
