confudled a bit on the Bassani ORP
Old Sep 4, 2003 | 07:24 AM
teke184's Avatar
got my orp and was looking at it...
it has 3 o2 bungs welded in. i know you need the two front sensors for proper engine fuction. but what the heck would the 3rd be for?
why would the have you reinstall ONE rear sensor into the pipe when it wouldn't even be used?
Old Sep 4, 2003 | 12:53 PM
V6toZ28's Avatar
You have a 99 ... I believe the driver side front O2 bung is in the manifold, the driver side rear is in the y-pipe and the passenger side has the front and rear in the Y-pipe.
The more important question though is, why does an ORP even come with the rear bungs???
Old Sep 4, 2003 | 01:23 PM
96SFLZ's Avatar
Just a guess but if the first two are for the front O2s and there's a single bung behind them then I guess it's possible that it's for a wideband O2?
Old Sep 4, 2003 | 01:29 PM
teke184's Avatar
talked to the guy i bought it from.
v6toz28 you are right, the one front sensor is in the manifold and the other 3 are in the ypipe.
he said he called bassani and they said that the other two were for a/f meters or things like that
Old Sep 5, 2003 | 12:15 AM
AL SS590 M6's Avatar
Moderator
Just do like I did and go to an autoparts store to buy some plugs for the extra holes.
Double aught
Oct 2, 2015 11:29 PM
greenzee28
Sep 25, 2015 04:29 PM
Greg88
Sep 20, 2015 07:14 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
