comp cam and 5.3 heads
Old Jul 11, 2007 | 06:39 PM
bigdawg6114's Avatar
is this a good cam with 5.3 lm7 heads; comp cam specs are .581/.592 lift. 224/230 duration @.050 with a 114 lobe seperation.
Old Jul 13, 2007 | 10:38 AM
Kraest's Avatar
Retired
Good for what? Forced Induction? NA? Street car? Drag car? Weekend car?
Your question is too vague.
Old Jul 13, 2007 | 03:06 PM
For a street car, trying to reach around 400hp
Old Jul 14, 2007 | 07:25 AM
Kraest's Avatar
Retired
Daily driver or weekend car?
It'd be decent for a daily driver, but on the tame side if you have a weekend car.
I'd go with the Futral Motorsports F-13 for the best of both worlds.
Old Jul 15, 2007 | 12:08 AM
I don't want to have to change anything else but the cam, can i do this with this cam...
Old Jul 15, 2007 | 02:08 AM
GhostZ28's Avatar
the cost of labor of putting New valve springs and pushrods is minimal considering the benefit. you should always want to do that, or buy a S/C and get it tuned. Why are you talking about changing out heads but not replacing the valve springs and such? that is ridiculous
Old Jul 15, 2007 | 04:19 AM
AL SS590 M6's Avatar
Moderator
You can NOT change just the cam. You have to support the higher lift with better valve springs and pushrods at the very minimum.
Old Jul 15, 2007 | 12:30 PM
Kraest's Avatar
Retired
bigdawg6114, you have PMed me numerous times about this situation along with posting threads on the board while all along getting the same answer:
YOU MUST CHANGE OUT YOUR VALVETRAIN AND OTHER SUPPORTING PARTS WHEN USING AN AFTERMARKET CAMSHAFT INCLUDING, BUT NOT LIMITED TO:
Valvesprings, pushrods, timing set, and oil pump
Old Jul 15, 2007 | 02:35 PM
Guys thanks for the input. I apologize if i ask, but i am a newbie when it comes to this and you get people telling you different things. Kraest you've been great. I really appreciate your help and your patients
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
