Clunking noise from rear end.
Old Mar 26, 2011 | 06:14 PM
scot337's Avatar
Just bought an 02 z28 and noticed a clunking noise from the rear end area of the car while going over bumps. I was told by the mechanics at the place I bought it from that it was the shocks. I replaced the shocks (which appeared to be loose) and the noise is still there. Any advise would be appreciative!
Old Mar 28, 2011 | 02:01 AM
miss97z's Avatar
Re: Clunking noise from rear end.
sway bar links or control arm bushings??
Old Mar 28, 2011 | 04:12 AM
chevy_dude97's Avatar
check your exhaust loop for wear just above the rear end, I found my exhaust had gotten loose at the y pipe and it was off by about half an inch a the loop causing it to bang over "hardish bumps" I just r2 the u clamps and moved it fwd... no more noise!
Old Mar 28, 2011 | 10:07 PM
scot337's Avatar
Thank you. I was kinda thinking that it was maybe the springs. Do the rear springs sit in seats that can be worn out? I will check the exhaust as well.
Old Mar 29, 2011 | 09:29 AM
AL SS590 M6's Avatar
Moderator
No seat on the bottom but a seat at the top.
Old Mar 29, 2011 | 09:30 PM
Evolution223's Avatar
I would bet it was the exhaust as well, I've owned 3 f-bodies and exhaust clunks are common, if someone ran over a curb, which I have done twice myself, then the exhaust could be bent,
Old Apr 5, 2011 | 08:05 PM
scot337's Avatar
Thumbs up Re: Clunking noise from rear end.
I figured it out, it was a combination of the rear lower control arm bushings and the right rear exhaust mount bushing. Replaced those and the noise is gone. Thanks everyone for the advice.
HarleyZ28
Oct 5, 2015 06:23 AM
Fatdog2
Feb 12, 2015 12:24 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
squarehead
Nov 21, 2014 08:02 PM
